Rical26
Posted: Sat Jul 10, 2010 5:19 am Post subject: bolt size needed please! |
Hi all, need help please!!
I'm looking for the bolt size that attach the wing strut to the
fuselage and the bolt size for the tailwheel (bolt that attach wheel
assembly to the spring)
Is it in the construction book?
Thanks!
Richard
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Jul 10, 2010 6:13 am Post subject: Re: bolt size needed please! |
From the Classic 4 Assembly Manual, What Model Kit fox is yours. I don't know if different models may use different bolts or not.
Parts List, Classic 4 Wing Kit
Lift Strut to fuselage--Bolt--AN6-11
Nut--AN310-6
Washers--AN960-616 and AN969-616L
Pins--AN380-3-3
The tail wheel to spring bolt is an AN7 and the length depends on what tail wheel and how many spring leaves it goes through. Mine is a Maule tail wheel and the bolt goes through one spring leaf. That bolt is an AN7-11. The nut is an AN310-7
Here's an AN bolt size chart if you need one.
http://exp-aircraft.com/library/alexande/hardfig2.html
_________________ Tom Jones
Classic IV
Ellensburg, WA |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jul 10, 2010 6:21 am Post subject: bolt size needed please! |
Richard,
The Model IV manual calls for a AN6-11 bolt at the bottom of the lift strut
and a AN5-20 for the tail wheel spring to fuselage attachment. The length
will vary depending on the number of tail spring leafs. The one mentioned
is for two leafs.
Lowell
Sent: Saturday, July 10, 2010 6:17 AM
Subject: bolt size needed please!
I'm looking for the bolt size that attach the wing strut to the fuselage
and the bolt size for the tailwheel (bolt that attach wheel assembly to
the spring)
Thanks!
Richard
dholly
Posted: Sat Jul 10, 2010 6:29 am Post subject: Re: bolt size needed please! |
For a M-III, from the Denny Aerocraft Parts List-
M-III Lift Strut to Fuse: AN6-11 Bolt, AN310-6 Castle Nut, AN960-616 Washer, AN380-3-3 Cotter Pin (new p/n MS24665-283)
M-III Tailwheel Assembly to Tailspring: AN7-10A Bolt, AN364-720A Elastic Fiber Stop Nut, A960-716 Washer
M-III Tailspring to Fuse: AN5-16 Bolt, AN310-5 Castle Nut, AN960-516 Washer, AN380-2-2 Cotter Pin (new p/n MS24665-132)
_________________ -Kitfox III 582 Blue/C Grove Spring / Aerocet 1100 Amphibs
-Airdale Avid+ (project) TD / W.I.B. Gear |
Rical26
Posted: Sun Jul 11, 2010 11:42 am Post subject: Re: bolt size needed please! |
Thanks to all for your response!
Cheers
Richard
