rowlandcarson(at)gmail.co Guest
Posted: Fri Jul 16, 2010 4:54 am Post subject: cm to fuselage reinforcement |
The manual calls for BID reinforcement of the
joint between the cockpit module and the firewall:
"Scuff sand the firewall and the cockpit module's
flanges abutting the firewall in preparation for
bonding. Lay-up three plies of 'bid' at +/-45°,
lapping a minimum of 2.5 cm (1") onto each part. "
It doesn't seem clear to me whether the areas to
be reinforced include the bottom edge of the
forward face of the rudder-pedal support flange
as well as around the sides and top of the
tunnel. It could be argued that the forward face
of the rudder pedal support flange is abutting
the firewall but I would have expected an
explicit call-out of that.
So is the BID reinforcement required only around
the 3 edges of the tunnel, or out across the
footwells too?
Next, the BID strips at the rear of the cockpit
module. I assume they just go transverse, and are
not taken around the corner into the central
tunnel. The build manual (p17-6) does not say how
wide these strips should be, but I assume that a
1" (25mm) overlap on each surface, as for the
CM-to-firewall strips, is OK.
I'm asking these questions here because
Kirkbymoorside doesn't seem well-set-up to deal
with technical queries as present.
in friendship
Rowland
| Rowland Carson ... that's Rowland with a 'w' ...
| <rowlandcarson(at)gmail.com> http://www.rowlandcarson.org.uk
| Skype, Twitter: rowland_carson Facebook: Rowland Carson
| pictures: http://picasaweb.google.com/rowlandcarson
gregoryf.flyboy(at)comcas Guest
Posted: Fri Jul 16, 2010 8:50 am Post subject: cm to fuselage reinforcement |
Hi Rowland,
I remember scratching my head there too, and for the same reason. Not sure
what others did, but I can report on my version of what the manual meant to
say.
In the front, I only used the plies at the top and sides of the tunnel only,
not at the rudder pedal flanges (only 3 areas of ply). The lower end of the
side re-enforcement plies, stopped at the start of the upper part of the
rudder pedal flange.
In the Rear, they were kept transverse, and the bid strips stopped at the
corner before entering into the tunnel, though it would only add strength at
a slight weight penalty.
I assumed the manual meant 1" overlap in the rear as well, though mine were
a bit over 1" overlap, to clear the flox corner.
Greg
____________________________________________________
--> <rowlandcarson(at)gmail.com>
So is the BID reinforcement required only around the 3 edges of the tunnel,
or out across the footwells too?
Next, the BID strips at the rear of the cockpit module. I assume they just
go transverse, and are not taken around the corner into the central tunnel.
The build manual (p17-6) does not say how wide these strips should be, but I
assume that a 1" (25mm) overlap on each surface, as for the CM-to-firewall
strips, is OK....
in friendship
Rowland
