Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Mon Jul 26, 2010 8:34 am Post subject: Coolant temperature sensor |
Good day,
Perhaps I need a logic translator to prescribe the directions I read from the following: (legal ramifications are NOT involved here)
In the Rotax 914 series Installation Manual sits a table on page 48/01JUL’08, above which the following text is set:
“Depending on the achieved maximum values of the cylinder head temperature and the coolant temperature following action are necessary.”
The table then exhibits ‘maximum values for Coolant temperature and cylinder head temperature’, under which for certain values the corrective action is “Additional instruments for displaying coolant temperature is necessary....”
Am I wrong or do I need to install a coolant temperature sensor to see if I need to install a coolant temperature sensor?
I’m sorry to disturb otherwise normal activity to address this logic twist, but I would appreciate any response applicable......
Cheers, Ferg [quote][b]
brian.davies(at)clara.co. Guest
Posted: Mon Jul 26, 2010 11:34 am Post subject: Coolant temperature sensor |
EER! Yes!
Actually, having recently carried out this exercise, the difference between the two temps is so small that it is not worth fitting a coolant temp sensor (IMHO).
Brian Davies
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fergus Kyle
Sent: 26 July 2010 17:28
To: 5EUROPALIST ; 1ROTAXnet
Subject: Coolant temperature sensor
Good day,
Cheers, Ferg[quote]
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Brian Davies
Posted: Tue Jul 27, 2010 4:55 am Post subject: Coolant temperature sensor |
Just one further point. Paul Mitchell has just reminded me that in the UK, the LAA have decided we must have both gauges fitted if we run 50:50.
Fortunately, I have run Evans since day one and have experienced no problems.
Brian
From: Brian Davies [mailto:brian.davies(at)clara.co.uk]
Sent: 26 July 2010 20:32
To: 'europa-list(at)matronics.com'
Subject: RE: Coolant temperature sensor
EER! Yes!
Brian Davies
http://www.matronics.com/c=================
