dons701
Posted: Tue Jul 27, 2010 1:48 pm Post subject: Solid nose wheel axle. Total nose gear weight |
Hi to all
Replaced my bent axle tube with a solid axle from ZAC. For what it's worth, the total weight of the entire assembly of wheel, tire, solid axle,aluminum fork(s)and nose gear strut ready to be slid back in was 17.8 LBS.
While I was at it, I also replaced the 1/4" thick green nylon nose gear bearings with 1/2" thick oil impregnated UHMW plastic(grey) I machined to see how they hold up. Also I have tried UHMW wear strips on the "V" notches that center the nose gear which seem to be doing well. I am doing this to get away from grease as it attracts dirt and is generally messy
_________________ Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop |
