Dave J
Posted: Thu Aug 19, 2010 8:56 am Post subject: Post Mod Weight and Balance |
Is anyone with a 601 and Jab getting weights similar to mine as follows:
Nose 204
Rt main 275
Lft main 278
Tot 757
If so, any thoughts of adding nose ballast?
(DO not know prior mod weights)
Dave J
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu Aug 19, 2010 1:43 pm Post subject: Re: Post Mod Weight and Balance |
Dave,
What flight scenarios cause you to want to add nose ballast? In my mind, there needs to be a specific reason to want to add dead weight to an airplane. My airplane is quite close to yours, but with about 10-12 pounds more per main wheel (601XL with Jabiru). Only at the most extreme case, which I have never needed to fly at yet, do I see me going out the rear end of the W&B envelope. That is two decent sized people and a lot of baggage in the back. I will more easily go over weight than I will go out the rear envelope. Thus, for me, adding nose ballast hurts more than it helps.
So where do you see yourself realistically wanting to load your airplane?
Congrats on completing the mods, by the way,
_________________ David Gallagher
Cincinnati, OH area |
jeffrey_davidson(at)earth Guest
Posted: Thu Aug 19, 2010 3:31 pm Post subject: Post Mod Weight and Balance |
Dave,
My 601 HD with the 3300A came in at 700 empty, 235 right, 235 left, 230
nose. I'm about 13 hours into Phase I concentrating on CHTs and the air
plenums, but I have had no problems at all with me (190 lb) and full fuel
(30x6=180 lbs) in two leading edge tanks. 700+190+180=1070 plus about 30 lb
misc gear. So I have flown it at about 1100 lbs or so at this point with no
problems or bad characteristics.
Jeff
Dave J
Posted: Fri Aug 20, 2010 7:06 am Post subject: Re: Post Mod Weight and Balance |
Thanks to all for your comments.
Let me add to my original post.
I would like to be able to invite an average male for a two hour flight in my 601xl. 10 pds of whatever in the baggage compartment.
I am 165 pds
average male 185
baggage 10
2 12 gal tanks
my weights and measurements are:
Rt main 275 pds , arm 668
lft main 278 pds, arm 673
Nose 204 pds arm -488
I have been crunching the numbers with Gary Ray's EXCEL spreadsheet at http://www.ch601.org/builder%20resources.htm
Dave
jeyoung65(at)aol.com Guest
Posted: Fri Aug 20, 2010 7:26 am Post subject: Post Mod Weight and Balance |
How did you come up with right main gear arm of 668 and 673 for the left main gear? Are the main gears located at at differance distance from the wing's leading edge? Jerry of Ga.
DaveG601XL
Posted: Fri Aug 20, 2010 8:17 am Post subject: Re: Post Mod Weight and Balance |
Dave,
I compared both your main and nose gear measurements to mine and they are all 45mm (1.8") or so more aft than what I measured on my 601XL. Per my W&B sheet from ZAC, the datum is defined as a "plumb line from wing leading edge at Nose Rib #4." Are you absolutely sure of your measurements?
I agree that the numbers you have posted show a serious aft CG problem, but I am wondering about the gear location dimensions. Please re-check using plumb bob with the top longeron level, tires inflated, hanger doors closed and on a flat surface. Have someone else do an independent measurement and see if both your numbers agree.
Good luck,
Z601c(at)anemicaardvark.c Guest
Posted: Fri Aug 20, 2010 11:20 am Post subject: Post Mod Weight and Balance |
I can't speak for Dave, but differences such as these are not uncommon, even
for certificated aircraft.
This is a difference of .7%. This kind of a difference can be due to minor
inaccuracies in the scales used. It can be due to minor human errors in
measurement.
Two sides of a plane rarely weigh the exact same amount. One side of the plane
may actually be 5 pounds heavier than the other side.
In my aircraft, the left side has the landing lights and pilot static system
in it. I suspect, when I finish, I'll see it slightly heavier than the other
side.
On Friday 20 August 2010 10:24:36 you wrote:
| Quote: | How did you come up with right main gear arm of 668 and 673 for the left
Jim B. Belcher
BS,MS Physics, Math, Computer Science
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
Posted: Fri Aug 20, 2010 11:57 am Post subject: Post Mod Weight and Balance |
Woops! My bad ...I see you said moment arm, not weight. Sorry about that!
On Friday 20 August 2010 14:18:44 you wrote:
even for certificated aircraft.
measurement.
plane may actually be 5 pounds heavier than the other side.
system in it. I suspect, when I finish, I'll see it slightly heavier than
the other side.
Jim B. Belcher
A&P/IA
Jim B. Belcher
A&P/IA
bryanmmartin
Posted: Fri Aug 20, 2010 12:43 pm Post subject: Post Mod Weight and Balance |
If your measurements are correct, you do have a problem. With that load, you'll hit the aft limit after burning off just six gallons of fuel. Where is your battery located? Is there any installed equipment you can move forward/
On Aug 20, 2010, at 11:06 AM, Dave J wrote:
I am 165 pds
average male 185
baggage 10
2 12 gal tanks
Dave
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
flyadive(at)gmail.com Guest
Posted: Fri Aug 20, 2010 1:03 pm Post subject: Post Mod Weight and Balance |
Jerry & Gaggle:
I gather these numbers are in mm... And I think in inches.
So this works out to just about 3/16".. THAT IS NOTHING! Very easy to be off that much and I think the guy did a GREAT job of measuring.
As stated before it is VERY easy to be off in wheel weight. I worked on a RV6 that had 50 pounds difference between wheels. Why? Not sure but there was an auto pilot with a huge servo motor.
Barry
On Fri, Aug 20, 2010 at 3:18 PM, Jim Belcher <Z601c(at)anemicaardvark.com (Z601c(at)anemicaardvark.com)> wrote:
[quote] --> Zenith-List message posted by: Jim Belcher <Z601c(at)anemicaardvark.com (Z601c(at)anemicaardvark.com)>
measurement.
side.
Jim B. Belcher
A&P/IA
target="_blank">http://www.matronics.com/Navigator?Zenith-List
http://forums.matronics.com
le, List Admin.
