george(at)gesoco.com Guest
Posted: Fri Aug 20, 2010 9:34 am Post subject: V530 Propellers |
I recently received an overhauled prop and an additional set of overhauled blades for the V530. Call if you need either.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/
SKYPE george.coy
richard.goode(at)russiana Guest
Posted: Fri Aug 20, 2010 9:33 pm Post subject: V530 Propellers |
Hi George,
Thanks for that and for thinking of us!
I suspect the cost of shipping,coupled with a stronger dollar,is going to act against it making sense for us,but how much,please??
Our problem on the V 530 is that we have had them all overhauled in Lithuania,and a consequence of them joining the EU is that they suddenly have very tough controls on all industrial waste,and particularly the waste products from chroming.
One item that seems to wear is the blade retainers,and the solution has been to hard-chrome,and then grind back to size,but this new legislation has effectively stopped this,so we have a lot of props stuck with no blade retainers,and are trying to find other places to do the work!!
Boris has "disappeared" again,just as he promised to deliver a Yak 50 to us that is now 3 years overdue!! He really can be a nightmare to deal with.
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
qaz11
Posted: Sat Aug 21, 2010 3:06 am Post subject: Re: V530 Propellers |
The 15 tooth spline is the low gear gear case. It's designed to accommodate a large dia prop. Depending on your size of boat, which you failed to mention, I would have to say that a 14.25 X 17 thru 15 X 17 would be your best bet. Now if you have a bass boat, the 13.5 dia.would be the correct choise, but the 17 pitch would leave lot's to be desired hence that pitch is for standard applications. That's a 1977 by the way. How big is your boat ?......................What you are describing is the length of the barrel.wrong thrust washer or just the wrong prop. If it were mine I would put a UN200PTC3R17S-3 with the UN087 thrust washer on there. But being you are the E bay shopper, I would suggest crossing over the #'s that I have described, for a more affordable application. That be a 14.25 X 17 for a 4.75 gear case. Glad to help. Good luck.
Income Protection Insurance| Life Insurance Quotes
