occom
Posted: Fri Sep 10, 2010 1:56 am Post subject: Tailwheel steering setup |
Lost a steering spring last night, scary!! I am looking for pictures and advice on the setup so I can optimize the setup when I assemble new parts.
On my previous attempt I used two stretch springs that were on the aircraft when I got it, I notice most of the setups I have seen use compression springs.
Anyway, I want to do it the best way I can so I'll take whatever advise I can get, thanks.
Dave Goddard
KF IV 1050 / 582 / Warp
Tom Jones
Posted: Sun Sep 12, 2010 5:04 am Post subject: Re: Tailwheel steering setup |
I have the stretch springs and never had a problem with them. You do need to bend both ends of those springs so there is absolutely no way for them to come unhooked. Here's a link to a video on set up.
http://forums.matronics.com/viewtopic.php?t=56502&highlight=tail+wheel
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Sun Sep 12, 2010 2:38 pm Post subject: Re: Tailwheel steering setup |
I had the same problem a couple of times. I will never go back to extension springs.
I got a compression spring kit from Spruce for ~$25. Best investment ever. It is impossible for the springs to come off now. The only trick is to keep the chains tight and be sure your ruder stops are set properly as to not allow the tailwheel to unlock too easily. Both of these are issues I am still working on...
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
occom
Posted: Mon Sep 13, 2010 12:50 pm Post subject: Tailwheel steering setup |
Great info, thanks guys!
occom
Posted: Sun Sep 19, 2010 5:35 pm Post subject: Tailwheel steering setup |
I replaced my steering springs today with the way overpriced Maule set from ACS.
No need for any chain if you follow the setup instructions, (one link of you want them looser than specified). The results are quite good, with around 3/4" of pretension the tailwheel is quite responsive, and kicks out much easier than before.
Dave Goddard
jridgway
Posted: Mon Sep 20, 2010 2:21 pm Post subject: Re: Tailwheel steering setup |
you might also try using the MATCO optional 25 degree 'release' bars vs the standard 45 degree 'release' bars.
jack
