Posted: Wed Sep 15, 2010 7:36 pm Post subject: [Bulk] Re: [Bulk] Re: lower cowl attach alternatives |
Thanks Tim. Plate it is!
Linn
On 9/15/2010 10:45 PM, Tim Olson wrote:
It's just overkill. That metal plate doesn't move hardly at all...
and you really don't need more than that.
Tim Olson - RV-10 N104CD
On 9/15/2010 9:16 PM, Linn Walters wrote:
> <pitts_pilot(at)bellsouth.net>
> Which makes me ask .... why not use an aluminum angle and rivet to the
> firewall as well as the bottom skin??
> I don't plan on using the hinge in that area either .... just don't know
> how I'm going to do it yet. I do plan on using countersunk screws and
> tinnerman washers in that area.
> Linn
> Linn
> On 9/15/2010 8:53 PM, Strasnuts wrote:
>> Here is what I did. I replaced the rivets with AN426-4-5 rivets
>> instead of the An426-3's that were there initially.
>> Cust. #40936
>> RV-10 SB Fuselage
>> N801VR reserved
>> http://forums.matronics.com/viewtopic.php?p=312569#312569
>> http://forums.matronics.com//files/cowl_attach2_185.jpg
>> http://forums.matronics.com//files/cowl_attach1_163.jpg
>> http://forums.matronics.com//files/cowl_attach_158.jpg
