kenhaslett
Joined: 10 May 2010 Posts: 1 Location: Kilrush Ireland
Posted: Tue Sep 21, 2010 6:10 am Post subject: Cable tensions |
Folks
I've just got my Bird back into the air after being grounded for nearly 2 years awaiting the 'powers that B' coming up with a fix. I'm on a european register. I set the aileron and rudder cable tensions as per Zenair but am very unhappy with the result. The aircraft feels heavier than a C182.
Before the upgrade my aileron cables were set at 12lbs and the aircraft could be controlled very easily using my index finger resting in the 'Y' of the control column. The aircraft had the same feel and response to that of a modern glider. Now I have to hold the control column in my hand and use a lot of force to make a turn.
Same with the elevator. The trim is not as sensitive, not a bad thing, but once again requiring a lot more effort in comparison with the previous iteration.
I'm worried that the tension is putting significant loadings on the aileron bushings, bellcrank and supporting ribs.
Anyone else found similar problems and have they found a way round it.
Any help would be appreciated
Ken
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
mhubel
Posted: Tue Sep 21, 2010 2:00 pm Post subject: Cable tensions |
Ken,
It would seem that from the flutter analysis that 12 pounds tension
on the ailerons was determined to be near the edge of stability. As I
remember, it was just inside the stability window but with little
margin. Cable tensions that low may have contributed to some of the wing
failures that caused so many problems. I would not go anywhere near
there anymore.
I have always had the tensions set to the current (post update)
values so I can't say much about before and after but I can say that
with a bit of lubrication on all contact points, I find the ailerons to
have very low friction, nothing like a 172 "truck". I will say that
before I added the lubrication, it was a bit sticky. If you haven't
greased all points where cables rub on nylon and oiled the pins at the
cable ends, you might find that doing so will help.
I do find some friction in the rudder but that is probably from the
tension of the bungy cord on the nose wheel, not a part of the update.
The additional friction from the cable tension pulling on the nose
assembly probably does make it worse. I have some ideas on how to reduce
this but it is not so bad as to be a major problem in my case.
N708HU
Jabiru 3300
59 hours
On 09/21/2010 10:10 AM, kenhaslett wrote:
Quote: |
Folks
Ken
http://forums.matronics.com/viewtopic.php?p=313205#313205
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
tigerrick(at)mindspring.c Guest
Posted: Tue Sep 21, 2010 2:26 pm Post subject: Cable tensions |
Hi, Mark and Ken,
Using the SWAG method, it sounds to me like Ken may have inadvertently set his tensions too high. I seem to recall that the nosewheel needs to be fully extended to get the rudder cable tensions right, but his issue is with aileron and elevator control response. I have no idea what equipment was used to set the tensions, but on my tensiometer, it's pretty easy to look at the wrong scale!
And in my conversations with the folks at Zenith after the German GVT, they said that they really had to work hard to induce flutter with aileron cable tensions below 5 lbs - and this is without any counterweights.
My advice to Ken would be to confirm the accuracy of his tensiometer, make sure he's using the 1/8 cable scale, raise the nosewheel off of the deck when checking tensions, and try somewhere between 20 to 25 pounds. This is what has served us well on several Zenith 601s, and it shouldn't be a risky proposition assuming he's gone ahead and installed the aileron balance weights.
Having the right tensions still shouldn't result in controls that are hard to move.
Just my humble opinion. YMMV.
Rick Lindstrom
First Light Aviation Grp.
Home of CC#18!
Posted: Tue Sep 21, 2010 3:47 pm Post subject: Cable tensions |
Ken,
I use 15 to 25 lbs max cable tension and have never had a problem with loss
of tension as result. I also think you do damage to the light pivot points
when you overload them.
Flutter is not the problem and never has been. If you go much tighter, the
cables will perpetually be undoing tension.
