rparigoris
Posted: Fri Sep 24, 2010 8:14 am Post subject: Radio Shack 3 row 15 pin d-Sub |
Hi group
I need to find a connector that will fit into the stick of my Europa. It ends up the 9 pin connector I was using doesn't work too well since it became obvious I need 10 pins.
Radio Shack sells a 15 pin what they call D-Sub connector with 3 rows and is the same size as the 9 pin D-sub that Bob depicts for use as a connector for Ray Allen pitch servos.
This is a solder pot bent sheet metal connector, but the pins are smaller in size compared to normal D-sub pins as I am familiar with.
The package has them rated for 5 amps for 1 minute at 600v AC.
The highest current carrying in the connector will be by the pitch servo.
I want to mutilate the connector like Bob depicts for pitch servo so it will fit in stick, then wrap it with silicone tape to keep it together.
Anyone see anything wrong with using this connector for this purpose?
BTW #26 wire goes to the male connector from the stick switches, and the female connector is connected to two #22 5 conductor Tefzel cables. The #22 wires fit the solder pots, but #20 wire may not.
Thx.
Ron Parigoris
Posted: Fri Sep 24, 2010 10:40 am Post subject: Radio Shack 3 row 15 pin d-Sub |
with.
Yes, this is the "high density" version of the D-sub series connectors.
They are becoming increasingly popular in GA radio designs.
Garmin uses them a lot. The connector you're looking at is
the same one used to bring VGA video out the back of
your computer for the monitor.
Why does it need to be inside the stick?
Could you bring a pendant cable out of the
stick to some convenient location where you
can use a 25-pin connector with crimped pins?
No, they won't. The HD series is limited to 22AWG
or smaller.
rparigoris
Posted: Fri Sep 24, 2010 3:11 pm Post subject: Re: Radio Shack 3 row 15 pin d-Sub |
Hi Bob
Thx. for the reply.
It seems you are insinuation to not use this 15 pin connector.
What is your reasons to not use this high density 15 pin connector?
"Why does it need to be inside the stick?
can use a 25-pin connector with crimped pins?"
By having a connector inside the stick it would make for easy servicing of the switches "when" they get hurt.
The current routing of wires doesn't easily allow install of a D-sub. If you have a good reason to not use the high density 15 pin, I could arrange things where i could remove the stick to service switches.
Ron Parigoris
Posted: Fri Sep 24, 2010 3:32 pm Post subject: Radio Shack 3 row 15 pin d-Sub |
Quote: | The current routing of wires doesn't easily allow install of a
Give it a try. They're not "evil" . . . just
challenging. I don't fiddle with the solder
version of these connectors . . . like I don't
hand-solder 0805 surface mount parts either.
rparigoris
Posted: Wed Oct 06, 2010 12:20 pm Post subject: Radio Shack 3 row 15 pin d-Sub |
At 11:54 AM 10/6/2010, you wrote:
Nice work my friend. I've captured your pictures and
plan to add them to the earlier article I published
on modified connectors. Thanks for sharing.
rparigoris
Posted: Wed Oct 06, 2010 1:08 pm Post subject: Re: Radio Shack 3 row 15 pin d-Sub |
Hi Bob
Thx. again for your advice.
I will share two other connector mods, your ides perhaps with a twist or two.
I needed to exit out of a 50 pin machined gold plated D-sub connector. There are slim pickings for 50 pin covers no less something small, light and user friendly (ability to tighten aft screw). I modified this connector using a thin stainless tube (McMaster Carr) JB KWIKed to the side of the cover to allow tightening of the aft stainless screw (heat shrink protection where wires will rest). I used stainless cap screws from McMaster with a patch of adhesive on it. Kinda like using suspenders and a belt, I also added a #3 star washer (#3 fits #4 screw better IMHO), and a plastic thin washer underneath to hold the screw captive:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82017
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82020
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82023
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82026
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82032
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82029
Another D-sub connector I made a trapezoid shaped bracket to use it as a bulkhead connector. As far as the cover, I had to thin a little so the stainless cap screw adhesive ended up being the perfect length. I used the thin plastic washers on the bottom to capture screw. I needed to turn the jackscrew standoffs a little to fit with bracket and plastic washer (aluminium hex) extra thickness:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82280
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82283
http://www.europaowners.org/forums/gallery2.php?g2_itemId=84179
Not quite sure if it falls in under a modification to a connector, but it is a modification to holding the wires that go to the connector. On my port lower panel insert there is not a real easy way to hold wires in place and allow install and removal. I am using a piece of carbon fiber with double heat shrink where it is trying to short the two legs of panel mount LEDs (CF conducts a little). Thus i am using the panel mount LEDs to stand off the piece of CF which I am tying wires to. I can't remember where i saw something similar, but pretty sure it was on Aeroelectric:
See Lower port insert wiring 1 thru 5 near the bottom of page:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27305&g2_page=2
Ron Parigoris
