Tdawson(at)avidyne.com Guest
Posted: Tue Apr 18, 2006 9:29 am Post subject: Props |
I think we'll put both a three-blade and a two-blade prop on for good
measure, on concentric counter-rotating shafts (a la Fairy Gannett or
Soviet Bear). That ought to be good for some attention at OSH! ; )
TDT
Posted: Fri Apr 28, 2006 7:45 am Post subject: Props |
Down boy! : )
Hey, doesn't Van's sell the MT prop, now, too? Why don't we talk Van's
into doing a comparison between the props on one of the factory planes?
Makes sense to me . . .
TDT
40025
pdwalter(at)bigpond.net.a Guest
Posted: Fri Apr 28, 2006 5:05 pm Post subject: Props |
Is it correct that MT are manufacturing a two bladed composite prop for the
10
LessDragProd(at)aol.com Guest
Posted: Fri Apr 28, 2006 7:55 pm Post subject: Props |
Hi Paul,
MT Propeller will design a two blade, or four blade, or whatever you feel you want that is reasonable.
They can even provide an aluminum 2 blade or 3 blade propeller.
They designed a 3 blade "natural composite" propeller for the RV-10, because their engineering analysis showed this provided the best performance and overall characteristics. Especially being 18 pounds lighter than the 2 blade Hartzell.
A 2 blade "natural composite" MT propeller would weigh about 1 pound lighted than the 3 blade propeller. The 2 blade hub is much bigger to handle bigger blades required, and the 2nd order harmonic vibration present with a 2 blade propeller.
Jim Ayers
In a message dated 04/28/2006 6:06:57 PM Pacific Daylight Time, pdwalter(at)bigpond.net.au writes:
| Quote: | --> RV10-List message posted by: "Paul Walter" <pdwalter(at)bigpond.net.au>
10
