Posted: Fri Oct 08, 2010 7:51 pm Post subject: How much paint for a whole '10? |
I've started painting using a HVLP 3M/Accuspray gun and Axis turbine
to shoot an Imron Elite Polyurethane single stage. It's going well so
far. The ailerons and flaps are painted.
For those of you that have painted, how many gallons did you use (or
would use if painting the entire aircraft in 1 color)?
If I were to do it all in one color, I'd roughly estimate 3.5 to 4
gallons at the rate I'm going. Seems like a lot. Lohle's estimate was
2 gallons of white but that is a different system.
The Imron tech sheet recoomends 1.8 to 2.2 mils. Unfortunately there's
no where to measure my paint thickness on the ailerons and flaps. I
know I shot a an access panel at 3.0 mils but I was trying to go extra
heavy on it as a test. So I know I'm doing less that 3.0 mils but
probably more than 2.2 on the rest of the job so far.
Bill "I am curious " Watson
Lew Gallagher
Posted: Sat Oct 09, 2010 4:47 am Post subject: How much paint for a whole '10? |
Hey Bill,
I THINK it was 5 gal. of white, one of blue, and a quart of red. I'm not
positive, cuz I kept running out and sending Wes back to the paint store for
more! I was shocked at how much more surface there is on a plane than a
car -- not anal enough to do the math, just started shooting. I typically
shoot three light coats of final with 20-30 min. between coats. That
eliminates runs, fills rivet heads, etc. I don't have a clue as to mils.
By the way, I've not had any problems with the paint (acrylic enamel) except
for one item. I made the false assumption that the steps that came primed
from Van's would have been professionally primed, so I did not strip them
and do my process that I did on everything else (self etch primer, epoxy
primer, final coat). Now, six months later, my paint has chunked off at the
joint of the step and the down leg, because their primer did not bond
sufficiently to the steel. So I would recommend taking those down to metal
and bring them back up.
My process of grinding a shallow in both plexi and glass around all windows
and glassing in a half inch of fiberglass over the joint has resulted in a
joint that is still as perfect as it was the day I painted it. No cracks
after a hot summer. I'm very pleased with that.
I'd love to see pictures as you paint -- either post, private email, or
maybe I can get doped up enough to make the flight up to visit with Wes.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Sat Oct 09, 2010 6:25 am Post subject: How much paint for a whole '10? |
I'm using Stewarts system. So far very clean and smooth without major work,
I have done one test piece (leg pants) and think I have enough paint on it
that it's white and shiny.
They told me 2 gallons and truthfully, the paint goes on very thin, 4 coats
last being the thickest (1.75 on the fluid nozzle of my AOM K1) so I can see
that being a possibility. I mentioned to their excellent support that I
thought I needed thicker . They send a sample of what each layer should look
like and they told me I would be wasting paint if I applied more than that.
In other words, I did it right and it will probably be 2-2.5 gallons for me
of all white, but for you the paint may need to be thicker and hence need
more.
My paint is water based so I add another 25% to the mix, hence it going on
so thin.
I'll give a paint report in the future for anyone who is a looking for an
easy and home safe paint option.
Pascal
Sent: Friday, October 08, 2010 8:45 PM
Subject: How much paint for a whole '10?
I've started painting using a HVLP 3M/Accuspray gun and Axis turbine to
shoot an Imron Elite Polyurethane single stage. It's going well so far.
For those of you that have painted, how many gallons did you use (or would
If I were to do it all in one color, I'd roughly estimate 3.5 to 4 gallons
at the rate I'm going. Seems like a lot. Lohle's estimate was 2 gallons
no where to measure my paint thickness on the ailerons and flaps. I know
I shot a an access panel at 3.0 mils but I was trying to go extra heavy on
it as a test. So I know I'm doing less that 3.0 mils but probably more
Posted: Sat Oct 09, 2010 10:26 am Post subject: How much paint for a whole '10? |
Thanks for that - especially the tip about the step.
I've been documenting the paint on my Kitlog site under "Painting A-Z"
with pics.
http://www.mykitlog.com/users/index.php?user=MauleDriver&project=224
You are more than welcome to flight up and visit. Love to see the plane.
I think you know I'm at 8NC8 and I'm working here just about every
day.... and the weather is beautiful.
Bill "prepping the wings" Watson
919-824-4179
On 10/9/2010 8:43 AM, Lew Gallagher wrote:
Hey Bill,
not positive, cuz I kept running out and sending Wes back to the paint
store for more! I was shocked at how much more surface there is on a
plane than a car -- not anal enough to do the math, just started
shooting. I typically shoot three light coats of final with 20-30
min. between coats. That eliminates runs, fills rivet heads, etc. I
except for one item. I made the false assumption that the steps that
came primed from Van's would have been professionally primed, so I did
not strip them and do my process that I did on everything else (self
etch primer, epoxy primer, final coat). Now, six months later, my
paint has chunked off at the joint of the step and the down leg,
because their primer did not bond sufficiently to the steel. So I
would recommend taking those down to metal and bring them back up.
windows and glassing in a half inch of fiberglass over the joint has
resulted in a joint that is still as perfect as it was the day I
painted it. No cracks after a hot summer. I'm very pleased with that.
or maybe I can get doped up enough to make the flight up to visit with
Wes.
Later, - Lew
Posted: Sat Oct 09, 2010 12:21 pm Post subject: How much paint for a whole '10? |
Seems like all the systems are or can be done differently.
This Imron Elite single stage, if applied per the tech sheets, goes on
with a cross coat. That's 1 wet coat in one direction immediately (5
secs to a couple of mins) followed by a slightly drier coat in the
other. It's not meant to be thinned. It's not meant to be sanded or
otherwise touched. No clear coat.
Using this Accuspray/Citation/ bottom feed pressure cup combination
from AC Spruce
http://www.aircraftspruce.com/catalog/topages/cite4.php
I have a fixed sort of setup. Using the fluid nozzle supplied (1.1) and
a fixed air supply (I can only restrict but run it full out), it
performs in a pre-determined way. Using the Imron per spec gives a
certain paint delivery and minimal overspray. The only real variables
are spray pattern and the speed I move the gun.
I've played with fluid nozzle size and thinning some of the high fill
primer I used. In the end, I'm using the 1.1 and adding 5% thinner per
the tech sheet.
Looks good so far with a slight amount of orange peel comparable to what
I see on many new cars. Will definitely will go thru more paint than I
expected but it seems right.
Definitely a toxic, not home safe product. With fresh air respirator
and ventilated booth, it's fine.
Thanks for the feedback.
Bill Watson
On 10/9/2010 10:20 AM, Pascal wrote:
work, I have done one test piece (leg pants) and think I have enough
paint on it that it's white and shiny.
coats last being the thickest (1.75 on the fluid nozzle of my AOM K1)
so I can see that being a possibility. I mentioned to their excellent
support that I thought I needed thicker . They send a sample of what
each layer should look like and they told me I would be wasting paint
if I applied more than that. In other words, I did it right and it
will probably be 2-2.5 gallons for me of all white, but for you the
paint may need to be thicker and hence need more.
going on so thin.
an easy and home safe paint option.
Pascal
