franicaza(at)yahoo.com.mx Guest
Posted: Mon Oct 11, 2010 11:32 am Post subject: IVO prop degrees indicator |
Dear friends,
I´ve instaled a new IVO prop in my Kitfox classic IV with a Rotax 912S. I´ve seen complicated the way it operates, checking maniful presure, RPM, power, etc. I wonder if someone has found a system for IVO as simple as the Air-plast prop, an indicator of how much degrees the prop has in certain point, or something as a led gradual scale indicator as the trims have.
I appreciate in advance your opinions,
Francisco Icaza.
akflyer
Posted: Mon Oct 11, 2010 11:43 am Post subject: Re: IVO prop degrees indicator |
an IVO is the simplest prop to set that I have seen on the market. Just bolt it on, warm it up, do a static run up and see how many RPM you are turning. If you are not getting full RPM, crank a little out. If you are over revving, crank a little more in. You can tweek it a little bit to get the blades set just right for take off and cruise after a few flights.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
