gorejr(at)bellsouth.net Guest
Posted: Wed Apr 26, 2006 3:24 pm Post subject: Extra fuel tanks |
Is it possible to add the 15 gallon extra fuel with the quickbuild wing? I know alot of the fuel system is in place. Thanks!
Jim Gore RV-10
Griffin GA
LessDragProd(at)aol.com Guest
Posted: Wed Apr 26, 2006 5:18 pm Post subject: Extra fuel tanks |
How long did you want to sit?
At full throttle at 2100 RPM and 60 gallons, you can sit for 4 1/2 hours and still have a half hour reserve.
Jim Ayers
In a message dated 04/26/2006 4:25:55 PM Pacific Daylight Time, gorejr(at)bellsouth.net writes:
| Quote: | --> RV10-List message posted by: <gorejr(at)bellsouth.net>
Jim Gore RV-10
Griffin GA
av8or(at)cox.net Guest
Yes, the system is designed to be added to aircraft already completed if you are talking about the ones in January's 2006 Sport Aviation by SafeAir1.
JT Lenhardt
#40262
Albert Gardner
Posted: Thu Apr 27, 2006 7:01 am Post subject: Extra fuel tanks |
Our FBO here gives home-base pilots a excellent deal on avgas-at one point last year during the last run-up in prices, there was almost $2/gal difference in area gas prices. Bigger tanks would give me greater out and back range without having to refuel.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Posted: Thu Apr 27, 2006 5:12 pm Post subject: Extra fuel tanks |
What kind of speed and fuel burn do you get at these settings? Thanks Jim Gore
Date: 2006/04/26 Wed PM 09:17:48 EDT
Subject: Re: Extra fuel tanks
Jim Ayers
Jim Gore RV-10
Griffin GA
Posted: Thu Apr 27, 2006 7:55 pm Post subject: Extra fuel tanks |
Hi Jim,
Just differential numbers for now, since my customers RV-10 doesn't have all of the fairing on and it isn't painted yet.
This numbers were obtained at 8,000' density altitude at full throttle.
2500 RPM 20 gph
2300 RPM 15 gph +1 knot faster than 2500 RPM
2100 RPM 12 gph -6 knots slower than 2500 RPM
Jim Ayers
In a message dated 04/27/2006 6:15:36 PM Pacific Daylight Time, gorejr(at)bellsouth.net writes:
johnwcox(at)pacificnw.com Guest
Posted: Thu Apr 27, 2006 8:21 pm Post subject: Extra fuel tanks |
Jim, lets here the airspeed and MP at 8,000 DA, 2500 RPM, 20 gph, 3 blade MT and a Lyco at 260hp. My version was missing your answer to Jim Gore’s request for SPEED data.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com
Sent: Thursday, April 27, 2006 8:55 PM
Hi Jim,
2500 RPM 20 gph
Jim Ayers
What kind of speed and fuel burn do you get at these settings? Thanks Jim Gore |
Posted: Fri Apr 28, 2006 7:12 am Post subject: Extra fuel tanks |
Hi John,
The manifold pressure was 23".
Regarding airspeed.
IMHO, the ONLY way to get VALID comparison airspeed numbers between propellers is to fly them on the same aircraft and engine WITH NO OTHER CHANGES MADE.
I have offered to pay the expenses and provide the 3 blade MT Propeller for a Hartzell propeller equipped RV-10 to do the testing. I think it says a GREAT deal that there have been NO TAKERS from RV-10's with the RV-10 Hartzell propeller.
What are you Hartzell drivers? CHICKEN?
With Best Regards,
Jim Ayers
PS Was that gauntlet to subtle?
In a message dated 04/27/2006 9:22:46 PM Pacific Daylight Time, johnwcox(at)pacificnw.com writes:
John Cox |
Tim(at)MyRV10.com Guest
Posted: Fri Apr 28, 2006 7:37 am Post subject: Extra fuel tanks |
I think it says a GREAT DEAL too. Things like:
* Being happy with their prop
* Content to leave things as-is due to satisfaction
* Unwillingness to remove some nicely saftied critical prop bolts
for no reason.
* Waning interest in spending more money
I know people would love to see the numbers on an MT, but it would
take more than an offer of "allowing" me to fly one for free
and go through the pain in the butt to pull those bolts and
put on the new prop. My feeling is, when something is buttoned
up nicely, you don't increase reliability by pulling it apart
a couple more times. In addition, there are still some minor
things I'd like to complete, and once you're flying already,
it seems that most everything drops to the bottom of your
priority list.
But, hopefully someone will bite, as it would be nice to see
the numbers.
Maybe it should go the other way....offer a Hartzell to someone
flying an MT. It's a cheaper prop to ship, and to buy to
send them.
LessDragProd(at)aol.com wrote:
| Quote: | Hi John,
Regarding airspeed.
OTHER CHANGES MADE.
With Best Regards,
Jim Ayers
John Cox
Posted: Fri Apr 28, 2006 2:46 pm Post subject: Extra fuel tanks |
The question remains… What was the airspeed in knots. I’m not engaging in the banter about valid airspeed. Just your number Please! The rest of the dialog is well known to the group about identical aircraft, identical engines, identical power settings. Am I the only one that has notices dozens of flying RV-10s and everyone is hiding their personal performance numbers?
About the only positive response has been on empty weight. No one is identifying their change in CG from the factory spec. There are lots of question on component placement that would help builders if there was less secrecy. At least Tim mentioned he did not have the loading problem as quoted by VANS. We should all be able to ask, “And what did he do to solve that obstacle?”
What is it about you MT prop twirlers that keeps data so close to the vest. I can’t make out your whisper, could you shout it once again please… Airspeed that is. I got the chicken part. Today is Friday and it smells fishy.
John - $-00.02
Sent: Friday, April 28, 2006 8:09 AM
Hi John,
Regarding airspeed.
With Best Regards,
Jim Ayers
John Cox |
Posted: Fri Apr 28, 2006 2:48 pm Post subject: Extra fuel tanks |
Touche' and an excellent solution to the challenge. My heart was in
hearing you pick up the gauntlet though. I suspect Hartzell sees little
advantage with 96% of the RV-10 market.
Posted: Fri Apr 28, 2006 7:41 pm Post subject: Extra fuel tanks |
Hi Tim,
A little oops here.
The Hartzell RV-10 propeller is unique to the RV-10. And only an RV-10 builder can buy one.
Best Regards,
Jim Ayers
In a message dated 04/28/2006 8:39:14 AM Pacific Daylight Time, Tim(at)MyRV10.com writes:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
(Stuff Cut)
flying an MT. It's a cheaper prop to ship, and to buy to send them.
Posted: Sat Apr 29, 2006 4:17 am Post subject: Extra fuel tanks |
Rent one from an RV-10 builder who bought one but didn't install
it yet. Still cheaper than shipping the MT across the country
twice.
| Quote: | Hi Tim,
A little oops here.
Best Regards,
Jim Ayers
(Stuff Cut)
