chasb(at)satx.rr.com Guest
Posted: Thu Oct 14, 2010 8:01 am Post subject: Lycoming IO-320 D1A Engine Problem |
I'd like to suggest an additional possible problem to check. You say the mags are timed correctly. Is it possible that one of the mags was timed 180 degrees from top dead center? Stranger things have happened.
Charlie Brame
RV-6A N11CB
San Antonio
[quote]Time: 07:02:27 AM PST US
From: rveighta(at)comcast.net (rveighta(at)comcast.net)
Subject: Lycoming IO-320 DIA Engine Problem
Guys, my neighbor in the airpark who is building an RV-9A, just began runni
ng his engine and it really runs rough - backfires,
black smoke, won't idle. He says he has set the timing properly.=C2- Any
input will be appreciated as to the cause.
Walt Shipley=C2-[b]
rveighta(at)comcast.net Guest
Posted: Thu Oct 14, 2010 5:30 pm Post subject: Lycoming IO-320 D1A Engine Problem |
Charlie, yes it's possible. I just learned the RV-9A owner had to remove the right mag due to some sort of interference. I suspect he may not
have gotten it back in correctly. We're going to start the engine tomorrow on both mags then see how it runs on just the left mag. Of course, if
the engine runs good on the L. mag, then we know the problem lies with the right mag.
Walt
bell
Posted: Fri Oct 15, 2010 5:24 am Post subject: Lycoming IO-320 D1A Engine Problem |
Keep us posted
Are they slicks or bendix…they both have their own special ways of incorrect installation..
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rveighta(at)comcast.net
Sent: Thursday, October 14, 2010 8:27 PM
To: rv-list(at)matronics.com
Subject: Re: Re: Lycoming IO-320 D1A Engine Problem
Walt
Posted: Sat Oct 16, 2010 6:58 am Post subject: Lycoming IO-320 D1A Engine Problem |
Just an update on my friends "engine problem." We started the engine again yesterday and switched from both mags to left mag. The
engine ran as bad or worse than before, so that was pretty puzzling. After some head scratching, I asked if I could sit in the plane and
start it, which I did. That was when I discovered the owner had the constant speed prop set on course pitch instead of fine pitch. When
I changed the prop setting, the engine ran great! Problem solved.
Thanks for all the input.
Walt
