		frank.hinde(at)hp.com Guest
				 Posted: Fri Apr 28, 2006 9:30 am    Post subject: Tail light |
				Hi guys,
 Just finishing up the details on the RV7a and wondered what methods you
 all used to fix the nut in the fiberglass rudder bottom to hold the
 tail/strobe light on.
 These are pretty small...like #4 screws (that look too short) is that
 correct?
 frank
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		phil(at)petrasoft.net Guest
				 Posted: Fri Apr 28, 2006 11:46 am    Post subject: Tail light |
				Before I cut the hole, I poured some epoxy resin in there to make the
 back about 1/2" thick.  Then simply cut the hole and drilled and tapped
 for the screws.  I'm pretty sure that I got some longer screws too.  I
 don't know what size but #4 sounds about right.
 Godspeed,
 Phil Birkelbach - Houston Texas
 RV-7 N727WB
 http://www.myrv7.com
 Hinde, Frank George (Corvallis) wrote:
  Hi guys,
 correct?
 frank
		fvalarm(at)rapidnet.net Guest
				 Posted: Fri Apr 28, 2006 1:17 pm    Post subject: Tail light |
				Why not just glue the nuts to the inside of the fairing?
 Bevan
		bnjn(at)tampabay.rr.com Guest
				 Posted: Fri Apr 28, 2006 6:05 pm    Post subject: Tail light |
				I actually saw this solution mentioned in the RVator but I don't remember
 when. The solution they recommend is to drill out the hole for the light. I
 think it is 1-1/8". Then insert the light with it's mounting bracket and
 drill the hole above and below. Mix up a thick mixture of epoxy and cotton
 flox. I use the West System so I use their micro-filler. I don't remember
 the actual product number. I then put in a glop of the mixture behind each
 of the small holes inside the rudder and let it harden overnight. The next
 day (or next work session) drill through the holes you previously drilled,
 insert the light and screw the small screws into the cured "glop". It fits
 very snug and is the easiest way to do it. I tried to epoxy those little
 nuts in the rudder bottom but they always stuck well to my finger and not to
 the fiberglass. Also, the inside of my rudder bottom had some pieces of
 fiberglass that had not bonded so it was like a thick hard shelf I couldn't
 cut through.
 Hope this helps. In my experience, it is the easiest way to do it. E-mail
 back if I didn't explain it well.
 Bill Near
		tadsargent(at)bellsouth.n Guest
				 Posted: Sat Apr 29, 2006 3:49 am    Post subject: Tail light |
				Frank I went the east route.  I replaced the nuts and bolts with stainless
 screws.  Just screw them in and fly.
 Tad
 N130TS
