Pneumatic connectors
david steade
PostPosted: Thu Oct 21, 2010 8:56 am    Post subject: Pneumatic connectors Reply with quote
Hi
I'm trying to get a supplier in the UK for the plastic quick connect couplings for the pitot static lines in the wing root.
Any help would be appreciated.
David Steade
David Steade
Bob.Fairall(at)fairalls.c
PostPosted: Thu Oct 21, 2010 9:06 am    Post subject: Pneumatic connectors Reply with quote
Europa supplied mine with my kit, but alternatively try http://www.tom-parker.co.uk/
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Steade
Sent: 21 October 2010 17:53
Subject: Pneumatic connectors
Hi
David Steade
- The Europa-List Email Forum ---> http://www.matronics.com/Navigator?Europa-List
g-iani(at)ntlworld.com
PostPosted: Thu Oct 21, 2010 12:16 pm    Post subject: Pneumatic connectors Reply with quote
David
You can get the common sizes from Europa such as the pitot and static. You can also get some sizes from RS Components.
If you want specialised sizes (I have used them on my fuel lines) the experts are Tom Parker Ltd (www.tom-parker.co.uk).
Let me know if you have any problems or want any advice on the specials, such a fuel.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
rampil
PostPosted: Fri Oct 22, 2010 10:57 am    Post subject: Re: Pneumatic connectors Reply with quote
I like the Winter 5 channel QDC
Find it at a local glider supply shop
(I use two extra channels for my AOA)
Ira N224XS
david steade
PostPosted: Fri Oct 22, 2010 11:22 pm    Post subject: Pneumatic connectors Reply with quote
Thanks for the replies
Supplier now located.
David Steade
David Steade
graeme bird
PostPosted: Tue Oct 26, 2010 1:10 pm    Post subject: Re: Pneumatic connectors Reply with quote
I'd be interested to know the conclusion to your investigation as I also need to procure some?
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
rparigoris
PostPosted: Tue Oct 26, 2010 1:47 pm    Post subject: Re: Pneumatic connectors Reply with quote
For what it's worth, I mutilated beautiful Winter connectors that also incorporate electrical connectors.
Sermos or Anderson power pole connectors are modular and semi water resistant.
I am using a very thin bungee to "yank" my mutilated connector into perfect position.
See Wing connect:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=31838
Also see about mid page two for only slightly mutilated Winter connector:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27305&g2_page=2
I purchased Winter 5 port from Paul:
http://www.cumulus-soaring.com/
and modular connectors and thin bungee from:
www.mcmaster.com
BTW McMaster sells the pneumatic connectors Europa supplies in more variants.
Ron Parigoris
rparigoris
PostPosted: Tue Oct 26, 2010 2:27 pm    Post subject: Re: Pneumatic connectors Reply with quote
Oops
Forgot the second link.
Ron Parigoris
