Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Sat Oct 23, 2010 9:09 am Post subject: Right Angle BNC Fittings |
Hi all,
I am wiring in my com and transponder antennae. The wiring would be a little more elegant with a right angle connector on the antenna. B&C markets a right angle fitting:
http://www.bandc.biz/bncrightangleadapter.aspx
That runs about six bucks. Aircraft Spruce has a right angle fitting
http://www.aircraftspruce.com/catalog/elpages/bncrfconnector.php
that runs about $46.
The question is, is there a significant dB loss using B&C's right angle adaptor as opposed to the right angle fitting from ACS?
Michael Wynn
RV 8 Finishing
San Ramon, CA
_________________ Michael Wynn
RV 8
San Ramon, CA |
jdabney(at)rice.edu Guest
Posted: Sat Oct 23, 2010 10:06 am Post subject: Right Angle BNC Fittings |
Michael,
I've had good results with the right angle connectors from Stein:
http://www.steinair.com/connectors.htm
Jim Dabney
On 10/23/2010 12:06 PM, MLWynn(at)aol.com (MLWynn(at)aol.com) wrote: [quote] Hi all,
Michael Wynn
RV 8 Finishing
San Ramon, CA
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Sat Oct 23, 2010 10:33 am Post subject: Right Angle BNC Fittings |
I “split the difference” with SteinAir for $17.50: “3 Piece 90 Degree Right Angle Male BNC Crimp Connector for RG-400 & RG-58 Coax Cable. Uses the same crimper as standard BNC's.”
Note that it is a crimp connector whereas B&C’s is female to male right angle. You will have one extra BNC connector to complete the connection.
Allen Fulmer
RV7 Cowling
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of MLWynn(at)aol.com
Sent: Saturday, October 23, 2010 12:06 PM
Subject: Right Angle BNC Fittings
Hi all,
Michael Wynn
RV 8 Finishing
San Ramon, CA
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
Bill & Sue
Joined: 10 Jan 2006 Posts: 48 Location: Malvern, Worcs. UK (Defford, Croft Farm)
Posted: Sun Oct 24, 2010 2:19 am Post subject: Re: Right Angle BNC Fittings |
Michael,
In a word: No.
Using a right angle adapter (or a right angle plug) won't make any detectable difference, so use whatever is convenient.
The ACS price seems rather alarming -your local electronics supplier should be able to come up with something for a lot less. Here in the UK my local supplier lists suitable adaptors and plugs from (the equivalent of) a couple of dollars...
Even top price ones like this:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=7122920&cm_vc=prev_uk
are still a lot less, which is quite surprising as I often order from ACS as the price and availability is vastly better than I can get in the UK even with the transport and tax included.
One thing to watch; whether you choose a a new plug or an adapter make sure you get the 50 ohm version. RF standard is 50 Ohm, but Video uses an almost identical 75 ohm connector with a slightly smaller inner pin.
Hope that helps
Bill
BobsV35B(at)aol.com Guest
Posted: Sun Oct 24, 2010 5:36 am Post subject: Right Angle BNC Fittings |
Good Morning Bill,
That which you have shown is, as you say, an adapter. The higher priced version is a right angle connector, not an adapter.
The adapter has a slightly higher, though still minimal, loss involved. It means that there are two connections involved in lieu of one and the right angle connector generally has a slightly smaller profile than does a connector and an adapter.
Make any sense at all?
Happy Skies,
Old Bob
In a message dated 10/24/2010 5:26:05 A.M. Central Daylight Time, Billandsue(at)billbell.co.uk writes:
| Quote: | --> AeroElectric-List message posted by: "Bill & Sue" <Billandsue(at)billbell.co.uk>
Michael,
In a word: No.
Hope that helps
Bill
Michael Wynn
Posted: Sun Oct 24, 2010 7:29 am Post subject: Right Angle BNC Fittings |
Thanks for everyone's input on this. I cruising the aeroelectric site, I found that Bob N has an instruction sheet on using adaptors to make a permanent right angle connector:
http://www.aeroelectric.com/articles/BNC_Rt_Angle/BNC_Rt_Angle.html
I can't imagine he would post this unless it was a perfectly viable approach to the problem.
Michael Wynn
RV 8 Finishing
San Ramon, CA
RV 8
San Ramon, CA |
Posted: Sun Oct 24, 2010 9:50 am Post subject: Right Angle BNC Fittings |
At 10:25 AM 10/24/2010, you wrote:
| Quote: | Thanks for everyone's input on this. I cruising the aeroelectric site, I found that Bob N has an instruction sheet on using adaptors to make a permanent right angle connector:
I can't imagine he would post this unless it was a perfectly viable approach to the problem. |
It's one approach that tolerates an extra joint in the
system . . . a low risk decision. It also exploits
ready availability of commercial off the shelf parts.
Bob . . . [quote][b]
Bill & Sue
Posted: Mon Oct 25, 2010 7:12 am Post subject: Re: Right Angle BNC Fittings |
Bob,
Yes it makes sense and of course you are quite right about the extra loss, but I challenge anyone to measure it at the frequencies concerned, let alone tell any difference in practice (we are talking about the equivalent of perhaps a few inches of cable).
Right angle connectors are harder to come by, but over here RS sell them for less than the price of the adapters.
The adapters are a little more bulky, but the most serious downside is the weight which will raise your stall speed by around 0.001%!
Cheers
Bill
| BobsV35B(at)aol.com wrote: | Good Morning Bill,
Happy Skies,
Old Bob
Speedy11(at)aol.com Guest
Posted: Tue Oct 26, 2010 7:13 am Post subject: Right Angle BNC Fittings |
For what it's worth, here's one data point for you.
I used a 90 degree BNC adapter between my transponder antenna and the coax and the transponder would not work. It was an adapter, not a connector. I switched to a straight coax to antenna connection (just barely had enough room) and it worked fine.
I have since sworn off ever again using a 90 degree BNC adapter.
Stan Sutterfield
Posted: Wed Oct 27, 2010 1:05 pm Post subject: Right Angle BNC Fittings |
At 10:08 AM 10/26/2010, you wrote:
| Quote: | For what it's worth, here's one data point for you.
I have since sworn off ever again using a 90 degree BNC adapter. |
But Stan, there have been gazillions of right
angle adapters produced and no doubt successfully
used in as many situations. The fact that you
suffered one instance of a failed installation
would be worthy of a failure analysis. There
is probably a logical cause for the effect that
has nothing to do with whether any particular
combination of connectors was installed.
