Arksey(at)aol.com Guest
Posted: Wed Oct 27, 2010 8:48 am Post subject: oil temp question 912 80 hp |
Hi again group,
on the 912 80 hp operating in this cool weather we are having trouble with oil temp being to low...i know you can tape the oil cooler to raise the temp of which we did, but we are reading oil temp on a EIS and it seemed to be jumping back and forth and not steady on a temp after doing this....also we have no temp probe on the coolant and therefore without one I do not feel like we should tape the coolant radiator....suggestions please.....thanks ....Jim
FIRESTAR ll 503 Michigan jswan
GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825
ph. 517-663-8488
Roger Lee
Posted: Wed Oct 27, 2010 1:08 pm Post subject: Re: oil temp question 912 80 hp |
Hi Jim,
Don't worry too much over the water temp as it is very close to the CHT since that is where the water runs through. If the oil temp looks like a ping pong ball, first check the wire connection on the sensor and make sure it is tight. The oil temp hopping around is usually a bad contact or wire connection.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
m.tucciarone(at)hotmail.c Guest
Posted: Thu Oct 28, 2010 2:59 am Post subject: oil temp question 912 80 hp |
I used to have to tape my oil cooler and radiator in the winter and fall. I bought a oil thermostat from Lockwood and it keeps my oil temp right at around 200f.
Sent: Wednesday, October 27, 2010 12:45 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: Re: oil temp question 912 80 hp
Hi again group,
ph. 517-663-8488
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
