JohnF
Posted: Sat Oct 30, 2010 12:06 pm Post subject: 912 ULS Oil Pressure Sender |
I need to replace the oil pressue sender on my Rotax 912ULS. Is the one that California Power Systems (their part #956355) has the one I need? The photo looks exactly like the one Lockwood shows as their #956357.
Your take on this?
pchristensen10(at)austin. Guest
Posted: Sat Oct 30, 2010 12:23 pm Post subject: 912 ULS Oil Pressure Sender |
Did you call Kitfox?
Pete
On 10/30/2010 3:03 PM, John Fasching wrote: [quote] I need to replace the oil pressue sender on my Rotax 912ULS. Is the one that California Power Systems (their part #956355) has the one I need? The photo looks exactly like the one Lockwood shows as their #956357.
Your take on this?
Roger Lee
Posted: Sat Oct 30, 2010 1:17 pm Post subject: Re: 912 ULS Oil Pressure Sender |
Hi John,
Those are the same and the genuine Rotax part for around $220.
You can get the identical VDO oil pressure sender from either of these guys for $35. It just won't have the anti vibration ring on it. I have seen some people take a heat gun and remove the ring and put it on the new sender. These two senders are the same VDO 0-150 psi 1/8-27 thread sender. It's just the ring that is different. 90% of the people just get the other sender for $35. You could purchase several of the less expensive ones for the price of one of the others. I have not had to replace one of the less expensive senders and I have replaced many of the one's with the metal ring on it. It's your choice. Lockwood's number is V360-004. This is the single pole sender. If you need the double pole that number is V360-025.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
imap8ntr(at)cox.net Guest
Posted: Sat Oct 30, 2010 2:24 pm Post subject: 912 ULS Oil Pressure Sender |
Good point, BUT only applies to experimental aircraft. If it is registered
as an S-LSA then we are stuck putting on only Rotax brand parts as per their
bulletin a couple of years (?) ago.
Ivan
rickofudall
Posted: Sat Oct 30, 2010 4:04 pm Post subject: 912 ULS Oil Pressure Sender |
Which part number is called out in the IPC?
Rick Girard
On Sat, Oct 30, 2010 at 3:03 PM, John Fasching <n29cx(at)ridgeviewtel.us (n29cx(at)ridgeviewtel.us)> wrote:
| Quote: | I need to replace the oil pressue sender on my Rotax 912ULS. Is the one that California Power Systems (their part #956355) has the one I need? The photo looks exactly like the one Lockwood shows as their #956357.
Your take on this?
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
tp://forums.matronics.com
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
