george.coy(at)gmail.com Guest
Posted: Fri Nov 05, 2010 8:06 am Post subject: M14P Top Overhaul Kits |
MOTORSTAR N.A. 714 AIRPORT RD. SWANTON VT. O5488
TEL. 802-868-2822 E-MAIL george.coy(at)gmail.com (GEORGE(at)GESOCO.COM) FAX 802-868-2822
November 2010
Product Announcement
MotorstarNA is proud to announce that we now offer TOP overhauled cylinder kit for the M14P engine. The cylinders are all first oversize. The first oversize or R-1 size cylinders are .15 mm oversize. The original nitride layer is typically .35 mm thick. This means the R-1 oversize only removes .075 mm of the nitride layer.
The kits will utilize the newly announced SPC pistons and rings. The kit includes al parts to accomplish a complete top overhaul. Each kit will contain the following:
9 – P/N 14-004-120-R1 Cylinders assemblies with valves and springs installed
9 – P/N 14-605-103SPC-R1 Pistons with fitted Rings installed
9 – P/N 14-605-121SPC Piston Plugs
9 – Sets of gaskets, lock tabs, push rod tube rubbers etc.
The Kit price is $15,690.00 outright. This includes a $250.00 core charge per cylinder. We will refund up to $250.00 per cylinder that are returned and found to be repairable.
The kit are also available as “ready to install” and include overhauled rockers, rocker shafts with bearing, all associated rocker hardware installed and wrist pins. The additional cost is $6,300 and the core credit increases to $300 per serviceable cylinder assembly.
The attached is a listing of the parts included in the Kit.
MotorstarNA plans to stock the kits in the U.S. for a quick turnaround.
Kit Contents:
Line item
Nomenclature
Part number
PC's/Kit
Cylinder
14-004-120
9
Exhaust valve
14-004-150
9
Intake valve
14-604-197
9
Spring
14-004-15
18
5
Spring
14-004-16
18
6
Washer
14-004-011
9
7
Washer
14-604-183
9
8
Plate
14-04-511
9
9
Plate
14-604-179
9
10
Safety
14-04-529
18
11
Safety
14-604-180
18
12
Bushing
14-004-014
9
13
Ring
14-604-201
9
14
Washer
14-604-200
9
15
Scraper ring
14-604-165
18
16
Cylinder base gasket
14-704-04
9
17
Rocker cover gasket
14-04-513
18
18
Rubber tube
14-707-04
18
19
Lock tab
14-204-16
27
20
Lock tab
15-04-22
9
21
Piston
14-605-103SPC-R1
9
22
Compression ring
300-0413
9
23
Scraper ring
302-0078
9
24
Oil ring
303-0322
9
25
Plug
14-605-121SPC
18
