rob10(at)tlb.sympatico.ca Guest
Posted: Sun Nov 14, 2010 7:52 am Post subject: Oil line |
I am getting ready to replace the oil hose from the cooler to the pump on my 912 because of a short radius bent that has been bothering me for a while. What is the best hose to use for that? Also, can the hoses be inverted on the cooler? In other words, is there an in and out ports or I can connect the hose from the pump in any end of the cooler and connect the hose from the tank in the other port?
Thanks listers
Jack
Model 4 Rotax 912
lcfitt(at)sbcglobal.net Guest
Posted: Sun Nov 14, 2010 9:02 am Post subject: Oil line |
Jack,
I solved that issue on my first Model IV when a friend gave me a length of Stainless Steel spring that I ran inside the tube to keep the walls from collapsing. Later after a question like yours no one seemed able to find the spring, so I did a little experimenting and found that if you wound a bit of the .032 or .041 SS safety wire around a mandrel you can essentially build a spring that you can put into the tube. I just tried it again and would suggest that you try different size rods to see what just fits in the tube. You could also use the shank of a drill bit to get finer size graduations - a lathe sure helps.
Once wound, stretch the wire coils out a bit to give more length and run it into the tube to the vulnerable bend area. Once under tension from the bend, it won't move.
Lowell
Sent: Sunday, November 14, 2010 7:50 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Oil line
Thanks listers
Jack
Model 4 Rotax 912
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Dick Maddux
Posted: Mon Nov 15, 2010 4:35 am Post subject: Oil line |
Jack you might try Merle Williams (at)[url=merlewilliamsaviation.com]merlewilliamsaviation.com[/url]. I bought a fitting that reverses the direction of the hose exiting the cooler outlet by 180 degrees in a very short space allowing me to use a short piece of straight run oil pressure hose to the pump. He has various fittings available.
Dick Maddux
912UL
Fox 4
Milton,Fl
MichaelGibbs(at)cox.net Guest
Posted: Mon Nov 15, 2010 8:24 am Post subject: Oil line |
Dick sez:
| Quote: | Jack you might try Merle Williams (at)<>merlewilliamsaviation.com...
Murle's name is spelled with a "u". His web site is, too:
<http://MurleWilliamsAviation.com>
Mike G.
Kitfox IV-1200 Speedster
Phoenix, AZ
