replacement windscreen review
rv10builder(at)verizon.ne
PostPosted: Fri Dec 10, 2010 10:37 pm    Post subject: replacement windscreen review Reply with quote
Back in October there was a request from Carlos at Cee Baileys asking for windscreens they could use to prototype a new replacement windscreen.
http://www.vansairforce.com/community/showthread.php?t=63632
I had some concerns with the quality of my windscreen as it simply did not fit as well as I would have like. I cut it to the black line and did everything I could, yet my windscreen had a problem where is bulged out over .250 gap on one side (right) I called Vans and they told me it was the first they had heard of this..Funny thing is I later discovered Tim Olson had the exact same problem mentioned on his webpage.
I jumped on the offer as Cee Baileys is down the road from me. They sent out a truck and took my windscreen and wingtip lenses. After two months and a couple refits the
screen was given back and fit into the canopy.
Vans has the builder on sect 45-08 trim and (retrim) and final trim and final fit, etc..in the first two steps (45-18 for the front window which references one to go back to 45-0Cool took me hours to get the fit decent. With the Cee Baileys these two steps are all be removed except for the "Final-Trim the perimeter of the front window as required to allow it to fit into the recess." From the time the windscreen was moved from the truck to the time it took to final trim and fit into my canopy was 30 minutes. The fit was close to perfect, which is normal since it was designed to fit all RV-10's with a little room for differences in each build. The quality of the Cee Baileys windscreen is excellent, I can't imagine there is much difference in the .250 width acrylic, but there is a difference in the clarity between the two. My understanding is that it's in the way the acrylic is stretched and fitted that makes this difference. It could also be that one was brand new and had less wear on it than the Vans one that required me to move back and forth to fit it over 12 (probably more) times. Hard to explain this but the new windscreen, maybe because it fit, looks much better on the plane than the trimmed Vans (warped) windscreen ever did.
The Cee Baileys wingtip lenses (vans VA-193)- Wow! now there this a difference in the quality of the plastic. The Vans stock is flimsy and feels cheap, the Cee Baileys lens, which BTW are also close to custom fitted, for allowance of the fiberglass differences, feel more solid and "durable". Been told it will outlast the Vans parts 2-3 times.
In both cases I am very happy with what Cee Baileys did for these parts, they are part of Desser Tires and have setup a webpage for the RV-10, I suggested they add the Cee Baileys parts to the Desser web page or as a minimum a link on the page for easy future reference.
http://www.vansaircrafttires.com/categories/RV%252d10/
On a personal note I have to say that Ken from Desser and Tom Bailey were outstanding to work with. They really are interested providing parts for the RV's out there and Ken mentioned he was working with Rapco to get brake pads specially made for the RV-10 so there would be another option to the builders. Ken has a commitment for early 2011. He told me that he will probably offer an introductory price that is far better than what is currently offered.
Another item he mentioned is that they provide upholstery for a OEM company. I suggested they consider doing the RV-10 seats as well an interior and a other work. I need neither but it may be another great option for builders. Lastly, Cee Baileys makes heat deflectors for certified aircraft. I asked that they consider making some for the RV-10 which it appears is hard to do without using suction cups and that has shown to be a 1 week or less solution, aka they fall off if a plane is left sitting in the heat for over 1 week. Ken is looking for options that might work.
So in the end I'm excited about the options Desser is looking to provide to builders. They already provide the stock tires we all get from Vans so it makes it that much easier for future builders to get a windscreen, lens and tires directly from Desser and skip it on the Finish kit list.. What really is exciting is what has developed for the RV-10 in aftermarket options since I started the project in 2007.
Hope this helps someone. I give this review to help those who still need to order/replace the Stock Vans parts and let you know there is another option versus getting it as part of the kit. The only thing I did gain from this is an exchanged replacement windscreen and wingtip lenses I gain nothing else.
Pascal
pitts_pilot(at)bellsouth.
PostPosted: Sat Dec 11, 2010 4:10 am    Post subject: replacement windscreen review Reply with quote
I haven't had a problem .... yet ..... but "the first they had heard of this" shows up here frequently, and in a recent discussion in the hangar! Must be the stock answer. Troubling.
Thanks Pascal, for the info.
Linn
[quote] I jumped on the offer as Cee Baileys is down the road from me. They sent out a truck and took my windscreen and wingtip lenses. After two months and a couple refits the
Pascal
Tim Olson
PostPosted: Sat Dec 11, 2010 9:08 am    Post subject: replacement windscreen review Reply with quote
I have heard of it from many people along the way over the
years, so it's another one of those "heard it a bunch
of times" (forum users) yet "never heard of it before"
(official company response) things. I did work through it
ok on mine, but it required lots of sanding and I'm sure
I thinned out the windshield in that area after sanding.
Not the most elegant thing. If this Cee Bailey windshield
fits a lot better and has equivalent thickness and specs,
then I think it's a good idea. I know if I ever have
to replace my windshield I will want one that fit better
than my first one, because I'd tear up a lot more
of the forward fuselage trying to glue and fill one
like my first, back in place.
One of these days I'll have to update and improve my
aftermarket add-ons area on my site to be more inclusive
of everything, and maybe list it in a Kit-by-kit format
so that builders can know what parts to delete from
their order, and buy substitutes, such as the nosewheel,
nosewheel axle, axle extensions, oil coolers for some
people, brake/fairing mounts, and all of those things
that you really probably are best off not installing
the stock item. It may make it easier for people buying
kits to just trim it down quick. Also, if enough people
vote by deleting items from the kits, perhaps they'll
think about why that is, and either change suppliers,
or improve their original parts....or best, include
these things in the kit as standard parts.
Tim Olson - RV-10 N104CD
that might work.
gain nothing else.
Pascal
dlm46007(at)cox.net
PostPosted: Sat Dec 11, 2010 9:21 am    Post subject: replacement windscreen review Reply with quote
I checked the site and did not see the replacement wing tip lens?
robin(at)PaintTheWeb.com
PostPosted: Sat Dec 11, 2010 9:41 am    Post subject: replacement windscreen review Reply with quote
Yeah Tim, when are you going to get around to updating your site? What have you been doing with all your free time? Slacker!
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Tim Olson
Sent: Saturday, December 11, 2010 9:06 AM
Subject: Re: replacement windscreen review
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
that might work.
gain nothing else.
Pascal
  November is the Annual List Fund Raiser.  Click on
.aeroelectric.com">www.aeroelectric.com
iption,
//www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
ttp://forums.matronics.com">http://forums.matronics.com
Checked by AVG - www.avg.com
Version: 10.0.1170 / [quote][b]
Tim Olson
PostPosted: Sat Dec 11, 2010 11:51 am    Post subject: replacement windscreen review Reply with quote
PostPosted: Tue Dec 14, 2010 3:46 pm    Post subject: replacement windscreen review Reply with quote
Site appears to be updated now.
http://www.vansaircrafttires.com/categories/RV%252d10/.
There is two options, drilled and countersunk for new builders and undrilled
for replacements. I suggested they drill the holes so all a builder needed
to do was position the lens and match drill the lens to the wingtip, saves a
few steps including getting a better fit.
Hope that helps!
Pascal
Sent: Saturday, December 11, 2010 9:18 AM
Tim Olson
PostPosted: Tue Dec 14, 2010 4:50 pm    Post subject: replacement windscreen review Reply with quote
PS: Especially for retrofit installs....nutplate spacings won't
be the same from plane to plane.
undrilled for replacements. I suggested they drill the holes so all a
builder needed to do was position the lens and match drill the lens to
the wingtip, saves a few steps including getting a better fit.
Hope that helps!
Pascal
Tim Olson
Personally, I would recommend them NOT predrill all
the holes. I know many builders have varied the number
of holes and nutplates used. I would rather drill them
myself.
Hope that helps!
Pascal
PostPosted: Tue Dec 14, 2010 6:33 pm    Post subject: replacement windscreen review Reply with quote
Basically they are all undrilled but IF someone orders the countersunk ones
they will be predrilled before shipping. I just figured having the holes
already drilled would help with the final drilling as all the wingtips
should be close to being the same so I suggested it thinking it would help
new builders. For retrofits, no question, undrilled. Hence the two options.
Pascal
Sent: Tuesday, December 14, 2010 4:47 PM
> Hope that helps!
> Pascal
Tim Olson
PostPosted: Tue Dec 14, 2010 9:50 pm    Post subject: replacement windscreen review Reply with quote
Sounds like they have it perfect then. Smile
ones they will be predrilled before shipping. I just figured having the
holes already drilled would help with the final drilling as all the
wingtips should be close to being the same so I suggested it thinking it
would help new builders. For retrofits, no question, undrilled. Hence
the two options.
Pascal
