dlm34077(at)q.com Guest
Posted: Fri Dec 24, 2010 9:01 am Post subject: new acrylic lens |
wait do not order yet..........................
mine arrived. They are frosted , not clear. Also had blue marker on them which has not been removed y me yet. I will be returning them to obtain clear lens.
Posted: Fri Dec 24, 2010 9:37 am Post subject: new acrylic lens |
Is this the Cee Bailey's lens?
frosted? that's the protective spray, just peel it off. they are all clear.
Pascal
Sent: Friday, December 24, 2010 8:55 AM
Subject: new acrylic lens
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Posted: Fri Dec 24, 2010 11:54 am Post subject: new acrylic lens |
You are correct; the lens peel both inside and out. looks a lot better now.
bbreckenridge(at)gmail.co Guest
Posted: Fri Dec 24, 2010 12:11 pm Post subject: new acrylic lens |
Whew! That coulda been embarrassing...!
On Fri, Dec 24, 2010 at 11:48 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
[quote] You are correct; the lens peel both inside and out. looks a lot better now.
Posted: Fri Dec 24, 2010 12:26 pm Post subject: new acrylic lens |
The peel coat is a lot thinner than I normally use so it looked like it was the finish. They send them in a box with a lot of bubble wrap for protection externally and internally
Robin(at)PaintTheWeb.com Guest
Posted: Fri Dec 24, 2010 12:56 pm Post subject: new acrylic lens |
By the way, the windscreen is the same way, it is actually very thin and also much easier to remove but being thinner makes it a little more fragile when working around it, aka- scratching. Also I can see the confusion with the frosted as Vans sends the lens as is without any protection for storage.
Did they fit as received? mine required minor adjustments but fit so much better than the Vans lenses did. Same goes for the windscreen, no bulge on the right as my Vans one had and pretty much fit with minor sanding on the sides.
Pascal
Sent: Friday, December 24, 2010 12:23 PM
Subject: Re: new acrylic lens
