jchang10
Posted: Sun Jan 02, 2011 1:08 am Post subject: Slickstart module location |
For those of you with the Slickstart module, where did you end up installing it? I already have stuff on the left top of the firewall. The center top of the firewall might interfere with accessing the oil filter. Thus, the right top is seemingly the best choice for me.
Just curious what others have done. Not sure what Van's did on their demo machine either.
http://www.myrv10.com/N610RV/undercowl/P0003082.html
Jae
40533
Posted: Sun Jan 02, 2011 10:36 am Post subject: Slickstart module location |
It can go just about anywhere. We've put them on the firewall,
adel-clamped to engine mount, behind the panel, etc. It's not too
critical.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sun, Jan 2, 2011 at 1:09 AM, jchang10 <jc-matronics_rv10(at)jline.com> wrote:
Posted: Sun Jan 02, 2011 2:15 pm Post subject: Slickstart module location |
That's where I put mine - right underneath the brake fluid reservoir.
On 1/2/2011 4:09 AM, jchang10 wrote:
jchang10
Posted: Sun Jan 02, 2011 4:41 pm Post subject: Re: Slickstart module location |
Thanks for the replies!
Interestingly, i asked another flying -10 builder, where he put his slickstart module, and he said what is that? Thus, a Mattituck IO540 with 2 slick mags, no EI, and no slickstart module, seems to start up fine with no issues whatsoever.
In the photo of N410RV, I don't see any "extra" wires going to their left mag, either. I plan to ask Van's about it this week.
Jae
40533
Posted: Sun Jan 02, 2011 6:43 pm Post subject: Slickstart module location |
Impulse couplings are the mechanical version of the SlickStart.
That's what people use if they don't have a SlickStart, or if you look
in the installation instructions you can uses a SlickStart with
impulse couplings for a belt-and-suspenders approach.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Sun, Jan 2, 2011 at 4:41 PM, jchang10 <jc-matronics_rv10(at)jline.com> wrote:
Jae
40533
http://forums.matronics.com/viewtopic.php?p=325362#325362
Kellym
Posted: Sun Jan 02, 2011 6:52 pm Post subject: Slickstart module location |
The Slick start was originally a replacement for the vibrator in retard
breaker systems such as the Bendix shower of sparks setup the Comanche
and many Mooneys used.
On 1/2/2011 7:39 PM, Dave Saylor wrote:
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Sun, Jan 2, 2011 at 4:41 PM, jchang10<jc-matronics_rv10(at)jline.com> wrote:
> Jae
> 40533
KCHD |
jchang10
Posted: Sun Jan 02, 2011 7:54 pm Post subject: Slickstart module location |
Actually, I assumed he had the same Slick mag, with just a retard
breaker. I don't know exactly what retard breakers do, but I am familiar
with impulse couplers, from the Cessna training days.
However, I can't remember if most Cessnas have dual or single impulse
coupled mags? I would guess single, but now I wonder why? Is there
anything wrong with having dual impulse coupled mags, other than extra cost?
Jae
40533
On 1/2/2011 6:50 PM, Kelly McMullen wrote:
retard breaker systems such as the Bendix shower of sparks setup the
Comanche and many Mooneys used.
> Saylor<dave.saylor.aircrafters(at)gmail.com>
> Dave Saylor
> AirCrafters
> 140 Aviation Way
> 831-722-9141 Shop
> 831-750-0284 Cell
>> "jchang10"<jc-matronics_rv10(at)jline.com>
>> Jae
>> 40533
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Kellym
Posted: Sun Jan 02, 2011 8:02 pm Post subject: Slickstart module location |
Cost and complexity is why many planes only have a single impulse
coupler. That is one mechanism prone to failure and subject of several
ADs. An engine needs something to retard the spark when starting to TDC
to avoid kickbacks. A retard breaker does this by a second set of
points, with pulsation to generate sparks created either by a vibrator
or Slickstart. Impulse coupling does it with a windup spring that
releases at TDC and decouples above cranking rpm by centrifugal flyweights.
On 1/2/2011 8:50 PM, Jae Chang wrote:
familiar with impulse couplers, from the Cessna training days.
cost?
Jae
40533
KCHD |
kdbelue(at)charter.net Guest
Posted: Sun Jan 02, 2011 8:19 pm Post subject: Slickstart module location |
Jae,
The Slickstart's main purpose is to be an electronic replacement for the electromechanical vibrator used with Bendix retard breaker mags, which is necesary because they don't use impulse couplers to start the engine. There is also a version of Slickstart for Slick mags, which helps those start better, but is not necessary. Slickstart works very well, but they quit making the Bendix version several years ago. Since I have Bendix retard mags on my RV-10, I wanted a Slickstart and called everywhere to find one in stock. I finally found one in Canada and bought it. I haven't seen any more. They still make the version for Slick mags.
Kevin Belue
On Jan 2, 2011, at 6:41 PM, "jchang10" <jc-matronics_rv10(at)jline.com> wrote:
Jae
40533
daveleikam(at)wi.rr.com Guest
Posted: Mon Jan 03, 2011 6:42 am Post subject: Slickstart module location |
G3i can take the place of Slick Start. Mounted mine right of center on the upper firewall.
David Leikam
RV10
N89DA
On Jan 2, 2011, at 3:09 AM, jchang10 wrote:
cjay
Posted: Wed Jan 05, 2011 7:34 pm Post subject: Re: G3i Ignition |
David (or anyone else),
Can you share any performance characteristics for the G3i system. I recall it debated on the list before but largely with somewhat insufficient supportive feedback, at least to my liking.
much regards,
cjay
Posted: Wed Jan 05, 2011 8:12 pm Post subject: Slickstart module location |
Do a search on VAF, there is a lot of positive feedback going back a few
months, most of those installers can answer how it has worked out since
than.
Posted: Wed Jan 05, 2011 9:29 pm Post subject: Slickstart module location |
I will be test running my engine in the next week or two.
I can't comment personally yet. Those I have spoken with who have the system like it.
Give Thomas a call at G3i. He is very straight forward on the operation of the system. A good guy.
David Leikam
RV10
N89DA
On Jan 5, 2011, at 9:34 PM, cjay wrote:
much regards,
cjay
http://forums.matronics.com/viewtopic.php?p=325751#325751
