		sblack
				 Posted: Mon Jan 10, 2011 2:53 pm    Post subject: CorvairEngines-List Digest: 4 Msgs -  01/08/11 |
  WW's cranks didn't break. WW doesn't make cranks. GM does and people have been using them since the early 60s, when WW (and I) were in diapers. To say that his cranks break is bizarre. If people are building new cranks or 5th bearings it is because of WWs research and effort and the cooperation of several high time engine builders who donated their cranks to be magnafluxed.
  WW did not work out the guts of the engine. GM did that. The guts other than the cranks work just fine and are readily available from Clarks.
  How many flight engines has MM built? How many hours have been flown on these new cranks? Will MM sell you one without having flown it? If so that should set off alarm bells. If they fly it and build up some hrs and can control the quality it might be a very good product, who knows. Nobody yet.
  sb
  |  | - The Matronics CorvairEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?CorvairEngines-List |
  _________________ Scott Black
Montreal
Jodel F11 O-200 |
		MRus597999(at)aol.com Guest
				 Posted: Mon Jan 10, 2011 7:34 pm    Post subject: CorvairEngines-List Digest: 4 Msgs -  01/08/11 |
				You don't get the point. WW uses used parts to build these engines, even  nitrided cranks break. WW builds their Corvair engines with 100,000 mile  used cranks.  And he doesn't guarantee any of  them. If WW  doesn't stand behind its product then don't build them. WW engines, some with  nitrided cranks, broke.... Period! However,  MM says use new parts,  including rods and NEW cranks. And that is what he is doing. I have seen  MM's  new engines, you obviously haven't.  The guts of these engines  involve brand new parts, not reconditioned ones. New is better than used.   I've studied WW extensively, talked to him, bought his stuff. As far as he goes  it's not bad..In fact I plan on buying some more of his stuff.   But MM is raising the bar. If you want to use 100,000 mile cranks, even  nitrided ones, go ahead. I will use a new crank that is 2 1/2 times stronger  than an original GM crank much less one with milllions of cycles on the  crank..  I'll  then be able to build an engine without an  even heavier 5th bearing.  These engines are too heavy as it is.
  Mike Russell
		rvickski(at)yahoo.com Guest
				 Posted: Tue Jan 11, 2011 4:37 am    Post subject: CorvairEngines-List Digest: 4 Msgs -  01/08/11 |
				Mike,
 Don't get me wrong, I like MM, his enthusiasm is almost contagious,
 but realize that only when the engine was pushed beyond it's limits or
 because of inferior post production workmanship, did bad things happen.
 You, and whomever told you, seem to lack understanding, which is
 readily apparent by your last three statements. To think that a new
 crank will somehow cure the bending forces imposed by a propellor or
 imply that properly reconditioned parts are not suitable, defies the
 evidence, reason and logic.  Saving weight is always a good idea but
 balance the notion with cost per pound saved then get yourself a Jab.
 Believe what you will, it's your truth, spend what you want, it's your
 money but please don't subject the rest of us with your parroted B.S.
 Put the time into your project, it's more productive than being a
 paper tiger.
 BTW I've seen and evaluated the cranks, gears, rods, pistons. All
 except the pistons, whiz bang stuff from the conscientious and well
 paid craftsman in land of Mao. Not that it cannot be any good, but how
 much better is it really? The rest? I reserve judgement.
 So, perhaps it's you who doesn't get the point.
 Man, I'm almost ashamed to post this publicly, debating with zealots
 is usually fruitless.
 Roy
