wingsdown(at)comcast.net Guest
Posted: Wed May 03, 2006 5:51 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Custom air oil separators as seen on sportflight pic post $150.00 each
CAP 140 complete hub assembly for NSI redrive, may fit others, no blades
$1,500 OBO
E.I digital EGT instrument, no probe $180 each or both for $300.00
Hand held radio Yaesu VXA-200. This was there top of the line model and
should be compared to same now, has altitude, density altitude, pressure
alt. Temp, VOR heading plus extra Nmhi battery and programming software
and cable, list was over $600.00 sell for $350.00
COM/nav antenna model VHF5-1 by AAE thin flat composite style list $125
sell for $85.00
E.I. Electronics International Digital Volt/Amp gage with over and under
voltage indication internal shunt model VA-1A list $285 sell for %200.00
Carb ice gage with sending probe $45.00
Intercom by PS Engineering model PM1000II with digital cockpit record
option $300.00
Electric clock model MD-90 $60.00
Turtle deck with smoke grey lexan, has scratch in glass 150.00 if you do
a pick up I have material for replacement.
Electric servo/ jack screw assembly $500.00 OBO
Wheel pant left side only painted ready to mount or repaint $50.00
Rudder $300.00
Elevator $225.00
VDO gages:
2 1/8 tack , water temp,oil pressure, boost, large RPM 3 1/8 maybe 1/4,
EGT make offer.
Cargo bay bag with aluminum custom fit bottom, no sagging. $95.00
Left long wing, moderate damage pick up only, $1,500.00
Right long wing major tip damage , $750.00
Lift struts, pair, faired $600.00 pick up only
Horizontal Stabilator faired strut braces pair $100.00
Trim assist attached to mixer $80.00
Low level fuel indicator, SS PN 10116.000 with factory drawing and
install instruction $125.00
Custom super trapp exhaust system. Will require the welding of a 3 bolt
flange to exhaust down pipe. $300.00 Pics on request.
EA-81 turbo engine parts, blocks, engine mounts left and right,
cranks, rods, push rods, heads, cams, open price to be set, accepting
offers.
NSI alternator pulley New $60.00
Stock small NSI oil cooler $50.00
NSI redrive new set of gears. Confirmed 2:23:1 $75.00 (sale pending)
NSI redrive gear puller $45.00 (sale pending)
SS flight controls all factory parts available in excellent condition.
Strut end farings. These go at the top of the strus for less drag.
$60.00 for the complete set never installed. (SOLD)
Carbon monoxide by coguardian. Plugs into lighter socket audible plus
digital level indicator. They have a web site. $99.00
I will try to keep this up to date and delete and add as necessary.
Once I receive a commitment to purchase I will remove the item from the
list.
Thanks so much
Rick
Posted: Thu May 04, 2006 6:35 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
each......................
$1,500 OBO.............
$300.00....................
pressure alt. Temp, VOR heading plus extra Nmhi battery and programming
software and cable, list was over $600.00 sell for
$350.00....................
sell for $85.00..................
%200.00.........................
Carb ice gage with sending probe $45.00..................
option $300.00..................
Electric clock model MD-90 $60.00.....................
a pick up I have material for replacement......
Electric servo/ jack screw assembly $500.00 OBO..................
$50.00............
Rudder $300.00..............
Elevator $225.00..............
VDO gages:
EGT make offer..............
$1,500.00....................
Right long wing major tip damage , $750.00................
Lift struts, pair, faired $600.00 pick up only................
Horizontal Stabilator faired strut braces pair $100.00.................
Trim assist attached to mixer $80.00................
install instruction $125.00......SOLD
flange to exhaust down pipe. $300.00 Pics on request....................
EA-81 turbo engine parts, blocks, engine mounts left and right, cranks,
offers................
NSI alternator pulley New $60.00.......................
Stock small NSI oil cooler $50.00..................
$75.00..............SOLD
NSI redrive gear puller $45.00....................SOLD
condition....................
$60.00 for the complete set never installed.....SOLD
Thanks so much
Rick
Jim Shumaker
Posted: Thu May 04, 2006 8:51 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Rick
I am putting the check in the mail for the VA-1A, $210.
Jim Shumaker
$50.00............
VDO gages:
Thanks so much
Rick
_________________ Jim Shumaker |
Posted: Fri May 05, 2006 5:04 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Sounds good Jim. I think shipping will be more like 15 or so. Please
send me your mailing address again if you don't mind. I will mark it as
sold.
Rick
Posted: Fri May 05, 2006 5:44 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
should be compared to same now, has altitude,density altitude,pressure
and cable, list was over $600.00 sell for $350.00....................
%200.00.........................SOLD
Carb ice gage Westach with sending probe $45.00.................
$50.00............
VDO gages:
NSI redrive new set of gears. Confirmed 2:23:1$75.00..............SOLD
digital level indicator. They have a web site. $99.00 ...............
Thanks so much
Rick
Posted: Sun May 07, 2006 11:08 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Carb ice gage Westach with sending probe $45.00.................SOLD
$50.00............
VDO gages:
Bendix/King fin type transponder antenna with ground plane plate
$50.00.....................
Airborne vacuum regulator valve model 2H3-23 #9AK FAA PMA list $728.00
in ACS catalog make offer..................
Airborne filter mount with filter best offer.............
Seat belt set both sides , with shoulder harness black
Thanks so much
Rick
Posted: Fri May 12, 2006 7:32 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Posted: Sat May 13, 2006 5:11 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
$50.00............
VDO gages:
Trim assist attached to mixer $80.00................(SOLD
Stock small NSI oil cooler $50.00..................(SOLD)
$75.00..............(SOLD)
Wood pistol grips modified one short on passenger PIC side regularl
length with PTTs $50.00 both..................
Mr. Funnel large for water seperation funnel filling of fuel
$20.00...............
Remote PTT $5.00 with other purchse..............
Fuel caps SS powder coated red nice $50.00 for the
set..................(SOLD)
Cessna dual vacuume gage with pop up no vac indicators can be used on
single system PN C668519-0101 $35.00............
Tire or tyre front Aero classic 11X4.00-5 8ply with new tube
$40.00......................
Cockpit light with flood or spot adjustment (model S1990) with red or
white light adjustment, with dim bright adjustment manufactured by
soderberg $55.00.......................
Landing light pulse unit. This is a CODE 3 unit model 700 which will
pulse or run steady, switch able $30.00. Beats the heck out of STC
units...........
Thanks so much
Rick
Posted: Tue May 16, 2006 1:30 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Just listed on Ebay wings and such under kitfox.................starting
bid is $1.00
Also just listed on Ebay flight gear bag and accessories under flight
bag.............
$50.00............
VDO gages:
units...........
Thanks so much
Rick
Posted: Sun May 28, 2006 12:33 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Aerobatics(at)aol.com Guest
Posted: Sun May 28, 2006 3:51 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Might be interested in radio, but first place I looked for a net price it
was 369 brand new....
if will to move let me know...
Dave
_Handheld Radios and Trancevers at Ace's Pilot Shop_
(http://www.acespilotshop.com/pilot-supplies/handheld/radios.htm)
