tsts4
Posted: Wed Feb 02, 2011 12:04 pm Post subject: Pirep on Lord 7545A/E urethane adhesive |
For those that used the Lord 7545A/E urethane adhesive in lieu of Weld-On or other products, would you still recommend it? If so, how many 50ml paks are required for the windscreen and all the windows?
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
aerosport1
Posted: Wed Feb 02, 2011 1:53 pm Post subject: Pirep on Lord 7545A/E urethane adhesive |
I believe I was the first one to use this adhesive and I would use it again. I have 185hrs on my 10 now and everything is great. I did some test prior to using and I found the bond to be better than weld-on. The great thing about
This is you can clean it up off the windows with PPG DT-870 reducer. This will not harm the acrylic or craze as the Weld-on can. This is a urethane
Adhesive and is not as hard as weld-on so it will not crack as easy. We use this Lord adhesives for many other applications here as well with great results. I would get the 215ML if you can and get 4 to 5. The 50 ML will not
Go far. You need about a 3/8" bead minimum al the way around the window frame. Go to album below there are some pictures
http://combsfamily.phanfare.com/3161550_4534177#imageID=74040224
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
tsts4
Posted: Wed Feb 02, 2011 2:13 pm Post subject: Re: Pirep on Lord 7545A/E urethane adhesive |
Thanks Geoff!
