bo124rs(at)hotmail.com Guest
Posted: Thu May 04, 2006 2:53 am Post subject: Oil dip stick housing length |
I need to know the oil dip stick "housing" length to fit under the 7 cowl.
As noted, this is for an O-360 A1A. I'm going by the salvage yard today and
the guys has probably 10-12 different lengths.
Hurry:-)
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
lifeofreiley2003(at)yahoo Guest
Posted: Thu May 04, 2006 5:06 am Post subject: Oil dip stick housing length |
10 1/2 inches top to the base where it would meet the case or 11 1/4 total over all length.
Darrell
Hurry:-)
Dana Overall
Richmond, KY i39
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
ronlee(at)pcisys.net Guest
Posted: Thu May 04, 2006 5:15 am Post subject: Oil dip stick housing length |
| Quote: | I need to know the oil dip stick "housing" length to fit under the 7 cowl.
Dana
I hurried. Did not stop to eat breakfast first. Sure am hungry now. But then
I am a sissy pilot.
On my RV-6A and O-360A type engine I measure my dipstick housing to be
6.25 " long. The Dipstick adds about 0.75" to overall system length.
From the bottom of the dipstick housing to the cowl is around 14.5".
My housing is too short and I have to use a funnel to add oil. If I were to
replace it, here is my reasoning:
14.5" available distance minus 0.5" measuring uncertainty minus 0.75"
for the dipstick minus 1" for clearance equals 12.25" dipstick housing length.
You could probably go as low as around 11" and still add oil without any
funnel/oil can extension and 2" (about 10" long) and use one of those 3"
On/OFF screw on extensions.
Hopefully others will have time to critique my thinking.
Ron Lee
cdeacon(at)myfsb.com Guest
Posted: Thu May 04, 2006 5:24 am Post subject: Oil dip stick housing length |
DANA: I JUST INSTALLED MINE ON MY ECI 0360 AND IT IS 13 INCHES.
GOOD LUCK, REMEMBER ME (RV4 CRASH) RICHMOND.
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu May 04, 2006 6:27 am Post subject: Oil dip stick housing length |
In a message dated 5/4/06 8:20:02 AM Central Daylight Time, ronlee(at)pcisys.net
writes:
| Quote: | >I need to know the oil dip stick "housing" length to fit under the 7 cowl.
and
If you wind up with too short a tube, here's one way to ease stick removal &
replacement:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5311
Still need a funnel, but this puppy only gets one quart between 40 hr
changes, so it ain't too bad. Don't forget to calibrate your stick on initial
fill-up regardless of what stick/tube combination you wind up with...
| Quote: | From The PossumWorks in TN
Mark Phillips
_________________ From The PossumWorks... |
Posted: Fri May 05, 2006 3:26 am Post subject: Oil dip stick housing length |
| Quote: | From: "Clarke Deacon" <cdeacon(at)myfsb.com>
Clarke and others, big thanks. Nice to have a salvage yard closeby.
So Clarke, the wife must be letting you finish the 7 . How's the 4 doing?
Dana Overall
Richmond, KY i39
Posted: Fri May 05, 2006 5:16 am Post subject: Oil dip stick housing length |
THE 4 IS JUST SITTING THERE ALL STRIPPED OUT. I'M FINISHING THE 7 AND
WILL MAKE THE REPAIR ON THE 4 A WINTER PROJECT.
