Rich L
Posted: Sun Feb 06, 2011 1:03 pm Post subject: Cracks in Crankcase |
Has anyone heard of the Crankcase cracking on a 912uls? SB-912-029 makes it sound like it can easily happen. Or is that CYA?
_________________ Rich Little
N812RL S-7 912ULS
North Idaho
Kiev Prop |
Roger Lee
Posted: Sun Feb 06, 2011 1:18 pm Post subject: Re: Cracks in Crankcase |
Hi Rich,
Maybe a little CYA, plus it includes some people that don't follow Rotax engine maint. recommendations, inspections or use after market parts and maybe even a few that want to use baling wire to hold things on.
I have not personally seen a cracked crankcase, but I'm sure it would not have been posted by Rotax unless something had happened. It sounds as if it is fairly rare, but something they wanted people to take notice about. I don't think I would be alarmed especially if you follow Rotax instructions. The Rotax 912 is a good solid engine and has been around since late 1989 and has steadily grown from its good reputation to one of the most popular engines today. Most of the complaints I have seen come from someone trying to treat it or compare it to some other engine, don't take the time to understand the Rotax or don't follow the Rotax instructions and do something on their own.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dick Maddux
Posted: Mon Feb 07, 2011 4:34 am Post subject: Cracks in Crankcase |
like it can easily happen. Or is that CYA?<
I heard about this happening in one of my recent 912 classes. Apparently too much pitch on the prop can over load earlier cases and create stresses leading to case cracking thus the min 5200 static (WOT) Rotax calls for in their bulletin.
Dick Maddux
Milton ,Fl
Roger Lee
Posted: Mon Feb 07, 2011 7:11 am Post subject: Re: Cracks in Crankcase |
Hi Dick,
Now that you mention that I do remember them talking about that in class. Just another good reason for people to follow Rotax recommendations and not branch out on their own and experiment. Rotax has many thousands of hours of experience and knowledge from a world's worth of 912's and 20 years of time not to mention their own testing. I think I'll defer to their wisdom and and keep my engine strong right up to TBO and beyond.
Tucson, Az.
Cell 520-349-7056 |
ronlee
Posted: Mon Feb 07, 2011 11:50 am Post subject: Re: Cracks in Crankcase |
I too remember reading Rotax 912 information about dragging the engine down by over propping as being the cause of cracking crankcases. I believe the MINIMUM required on wide open throttle is 5400 rpm.
I believe some have a tendency to want to run our engines at lower rpm then they were designed for. Maybe we feel they Will burn less fuel and or last longer. If anyone has different info please post.
_________________ Ron Lee
Tucson, Arizona |
Dick Maddux
Posted: Tue Feb 08, 2011 6:05 am Post subject: Cracks in Crankcase |
required on wide open throttle is 5400 rpm.<
Ron,
If you check the service bulletin you will see the minimum is 5200.
Dick Maddux
Milton,Fl
