Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Feb 15, 2011 8:20 pm Post subject: parameters |
I was wondering if anyone has ran across a list of parameters for the RV-10 with the standard IO-540 engine. I want to setup my EFIS parameters tomorrow for all the speeds, temps, rpms, etc.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rv10flyer(at)verizon.net Guest
Posted: Wed Feb 16, 2011 7:28 am Post subject: parameters |
Engine-Check out the Lycoming operators manual
Airspeeds- Check out the speeds provided by Vans in the Finish kit.
To get you started on Engine.
Tachometer Normal operating range. Green Arc 500/2700 rpm
Red Line (Max Continuous Power) 2700 rpm
Oil Temperature Green Arc Normal range 75 to 220 deg F
Red line Max 245 deg F
Oil Pressure Normal range 55 to 90psi
Start and warm up 115psi
Minimum (idle) 25 psi
Max 95 psi
Fuel Pressure Normal range 14 to 45 psi
Minimum 14 psi
Maximum 45 psi
Cylinder Head Temperature
Maximum Cruise 435 Deg F
Maximum engine life 400 F and below
Pascal
Posted: Wed Feb 16, 2011 11:13 am Post subject: parameters |
Here's a spreadsheet with settings from my AFS engine monitor. It's a
little hard to read at first but you'll get the idea.
These aren't the strict limits set by Lycoming. I've massaged them a
bit after living with the plane for a while. For example, if you set
the RPM limit at 2700, you'll get a nuisance warning at 2710 so I
bumped that up a bit.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Feb 15, 2011 at 8:20 PM, Strasnuts <sean(at)braunandco.com> wrote:
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=331192#331192
RUMS -
ite -
 Download |
| Filename: |
Engine_Parameters.xls |
20 KB |
| Downloaded: |
254 Time(s) |
