weeav8ter
Posted: Sun Mar 06, 2011 5:25 am Post subject: Speaking of seat rails |
Sent from my Iphone Wayne
Since were on the subject of seat rails I'm assuming some of you are having the same problem as me with the seat being very difficult to move as tome goes on. For those that have this same problem have you come up with an easy solution? Boy during this colder period it's almost impossible to get them to slide.
Wayne Edgerton
N602WT
partner14
Posted: Sun Mar 06, 2011 5:46 am Post subject: Speaking of seat rails |
I believe there's a strip of teflon/plastic in the rail. If you pull it out and just sand yourself a little more clearance, it should take care of the problem.
Don
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Sent: Sun, March 6, 2011 7:16:34 AM
Subject: Speaking of seat rails
--> RV10-List message posted by: Wayne Edgerton <w.edgerton(at)verizon.net (w.edgerton(at)verizon.net)>
Wayne = - List Contribution Web Site - &nbs=================
40636 |
Dick Sipp
Posted: Sun Mar 06, 2011 6:01 am Post subject: Speaking of seat rails |
One thing that was a mistake was lubing the rails with white lithium grease. Over time and with cold temps it made the situation worse. The teflon? is on the seat riders.
Had to clean out all the grease, they seem to work best without lube or perhaps some very light type. Have not tried that yet. If the tracks are the least bit out of alignment the problem is obviously worse.
Dick Sipp
350 Hours
Tim Olson
Posted: Sun Mar 06, 2011 6:35 am Post subject: Speaking of seat rails |
A little silicone spray helps.
On Mar 6, 2011, at 7:40 AM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]I believe there's a strip of teflon/plastic in the rail. If you pull it out and just sand yourself a little more clearance, it should take care of the problem.
Don
From: Wayne Edgerton <w.edgerton(at)verizon.net (w.edgerton(at)verizon.net)>
To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
--> RV10-List message posted by: Wayne Edgerton <[url=mailto:w.edgerton(at)verizon.net]w.edgerton(at)verizon.net (w.edgerton(at)verizon.net)[/url]>
rene(at)felker.com Guest
Posted: Sun Mar 06, 2011 7:26 am Post subject: Speaking of seat rails |
What type are you using. I have used the LPS-2 with a little success……but looking for something better…..
I thought it would get better over time, but after 150 hours….I have seen little improvement.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson
Sent: Sunday, March 06, 2011 7:26 AM
Subject: Re: Speaking of seat rails
Don
| 0123456789 Quote: | =================================== | 0 Quote: | =================================== | 1 Quote: | =================================== | 2 Quote: | =================================== | 3 Quote: | =================================== | 4 Quote: | =================================== | 5 Quote: | =================================== | 6 Quote: | =================================== | 7
Tim Olson
Posted: Sun Mar 06, 2011 9:04 am Post subject: Speaking of seat rails |
It's nothing too special...I'm not sure of the brand, maybe
"Gunk" or something...it's sold under so many brands.
It's just "Silicone Spray". It's not a normal oil lube
but real thin. I just sprayed a paper towel and then
wiped it onto the rails. You don't need to use much.
And, you don't want to get it on anything that you'll
want to paint later....but otherwise it's no big deal.
Don't use too much...you don't want to attract tons of
dirt and stuff.
Tim Olson - RV-10 N104CD
On 3/6/2011 9:23 AM, Rene wrote:
Quote: | What type are you using. I have used the LPS-2 with a little
Rene'
801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson
*Sent:* Sunday, March 06, 2011 7:26 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Speaking of seat rails
Don
<mailto:w.edgerton(at)verizon.net>>
*To:* "rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>"
<rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>>
*Sent:* Sun, March 6, 2011 7:16:34 AM
*Subject:* Speaking of seat rails
<w.edgerton(at)verizon.net <mailto:w.edgerton(at)verizon.net>>
*ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List*
*ums.matronics.com">http://forums.matronics.com*
*http://www.matronics.com/contribution">http://www.matronics.com/contribution <http://www.matronics.com/contribution%22%3ehttp:/www.matronics.com/contribution>*
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
