mtherr(at)yahoo.com Guest
Posted: Sun May 07, 2006 5:56 pm Post subject: Saddle damaging the stab skin |
Hello Group!
I am slowly working on my annual inspection and when I
removed the fuselage saddle on top of the stabilizer,
I got a bad surprise. The saddle made a faily deep
groove in the stab skin. I remember setting it up
with a clearance so this would not happen, but I
suppose that things move with time and in flight.
Anyway, I think I'll double up the skin between the
two center ribs with a 0.025 or 0.020 piece of
aluminum.
So flying friends, when you have time, check
underneath the saddle to see if you have the same
problem.
Michel
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://www.zenithair.com/bldrlist/profiles/mthobby
http://pages.infinit.net/mthobby
xl(at)prosody.org Guest
Posted: Sun May 07, 2006 9:51 pm Post subject: Saddle damaging the stab skin |
I wasn't comfortable using the saddle as the rudder stop.
Neither was my EAA tech counselor. We were concerned that
it could move around too much - not positive enough.
So I riveted a metal stop to keep the elevator from using
the saddle as the stop. Sounds like the elevator would have
pushed the saddle into my skin too.
I also didn't like using the edges of the skins/longerons
as the bottom stops. So, I used a couple of angles as the
bottom stops. This was a good thing to do. Because, the front
of the elevator contacted the edge of the rear stabilizer mounting
bracket (don't remember the technical name) in one small spot.
(Yes, things do tend to move around after your flying.)
And it made a slight dent where it touched. The same thing,
but worse, may have happened to the bottom of the elevator
if it was allowed to rest on the edge of the skins. On the
ground, if you let go of the stick the elevator falls and hits
the stops - or the edge of the skins.
(This is my 4th post today. A record for me.
The clouds were too low for me yesterday and today the
wind was 15kt, gusts 20kt at 90 degrees across the runway.
I was tempted but I stayed on the ground.....)
Thanks for the report, Joe E
N633Z (at) BFI
332 hours
CH601XL
On Sun, 7 May 2006, Michel Therrien wrote:
Quote: |
Hello Group!
.......snip
Michel
Posted: Mon May 08, 2006 3:15 am Post subject: Saddle damaging the stab skin |
JFYI, I am not using the saddle as a stop. I really
did not like the idea of using something that fragile
to retrain a control surface.
For the elevaor down stop, I originally attached a
piece of L angle to the fuselage so the elevator could
rest on a flat piece of metal. Nevertheless, what you
described happened. With the continuous friction on
the ground, the skin got ground on the elevator. I
intend to pull it, grind it to reduce the potential
for cracks and double the area with a 0.040" (and
replaceable) alum sheet for the contact area.
Michel
--- xl <xl(at)prosody.org> wrote:
Quote: | And it made a slight dent where it touched. The same
thing,
elevator
On the
falls and hits
