coop85(at)bellsouth.net Guest
Posted: Mon May 08, 2006 5:16 pm Post subject: Mag harness |
This is probably going to fall under the "stupid question" category, but I
have a Slick Magneto and the wiring harness came separately. There doesn't
seem to be any key or marking showing what direction it should be mounted,
although it could be I just can't see it due to the proximity to the
firewall. My obvious choice was to put the "LH" label on the outside. Any
other suggestions.
Marcus
Fuselage going to the hanger soon, wiring almost complete
flysrv10(at)gmail.com Guest
Posted: Mon May 08, 2006 5:35 pm Post subject: Mag harness |
I believe that there is only one way that the harness will fit the
back of the mags. Look carefully and you might be able to match the
screw pattern and back of the mag with the aid of a mirror.
Do not archive.
On 5/8/06, Marcus Cooper <coop85(at)bellsouth.net> wrote:
other suggestions.
Marcus
Posted: Mon May 08, 2006 5:42 pm Post subject: Mag harness |
Thanks, I figured it would be something like that but the screw pattern
SEEMED symmetrical. I'll take a closer look.
Marcus
Tim(at)MyRV10.com Guest
Posted: Mon May 08, 2006 7:15 pm Post subject: Mag harness |
Marcus,
Rob's right, there's definitely only one way that will properly fit.
Other orientations look close, but none will be just right except
for the one. It is definitely very hard to see from the angles you're
able to get to look.
Marcus
