sapril001(at)hotmail.com Guest
Posted: Sat Apr 09, 2011 6:01 am Post subject: Free Fuel Flow |
Hi all,
I have this question about the fuel flow needed for the M-14P 360HP engine.
What should be the free fuel flow value needed at the engine connection. ( Fuel Pump Inlet )
What is the maximum fuel consumption of the M-14P engine at take off power.
Sylvain April
Murphy Moose C-GFFO
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
george(at)gesoco.com Guest
Posted: Sat Apr 09, 2011 9:22 am Post subject: Free Fuel Flow |
You can use AN-6 or -8 hose and fittings.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Sylvain April
Sent: Saturday, April 09, 2011 9:58 AM
To: m14pengines-list(at)matronics.com
Subject: Free Fuel Flow
Hi all,
Sylvain April
Murphy Moose C-GFFO Quote: | http://www.matronics.com/Navigator?M14PEngines-List | 01234567
Posted: Sat Apr 09, 2011 1:18 pm Post subject: Free Fuel Flow |
Regarding the M14 fuel consumption: See attached.
Dennis
On 4/9/2011 12:16 PM, George Coy wrote:
Quote: | You can use AN-6 or -8 hose and fittings.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com <mailto:george.coy(at)gmail.com>
http://coyafct.com/
SKYPE george.coy
*From:*owner-m14pengines-list-server(at)matronics.com
[mailto:owner-m14pengines-list-server(at)matronics.com] *On Behalf Of
*Sylvain April
*Sent:* Saturday, April 09, 2011 9:58 AM
*To:* m14pengines-list(at)matronics.com
*Subject:* Free Fuel Flow
Hi all,
( Fuel Pump Inlet )
Sylvain April
Murphy Moose C-GFFO
*http://www.matronics.com/Navigator?M14PEngines-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Description: |
 Download |
Filename: |
M14_Power_Chart_Fuel_Consumption.pdf |
Filesize: |
61.56 KB |
Downloaded: |
893 Time(s) |
William Halverson
Posted: Sat Apr 09, 2011 1:46 pm Post subject: Free Fuel Flow |
Is fuel consumption linear? I ask because I have a 400HP M14PF ... have not ever seen a chart for that engine ...
Thanks!
William Halverson
N355YK
YAK-55
Posted: Sat Apr 09, 2011 2:34 pm Post subject: Free Fuel Flow |
The 400 HP is developed above 880 MM manifold pressure (35") which you
typically only see on takeoff (approx. 1000 mm or 40"). The fuel flow
at the higher manifold pressure will of course increase by about 2-3
gallons per hour. However as soon as you back off after takeoff, fuel
consumption will be as shown on the 360 hp chart.
Dennis
Thanks!
William Halverson
N355YK
YAK-55
n801bh(at)netzero.com Guest
Posted: Sat Apr 09, 2011 3:07 pm Post subject: Free Fuel Flow |
This will get you within a few gallons per hour for your fuel burn. On the Radial you can figure about .43 BSFC.
400 HP = somewhere around 28 gallons per hour
http://www.ehow.com/how_6315061_calculate-bsfc.html
Ben Haas
N801BH
www.haaspowerair.com
Posted: Sat Apr 09, 2011 3:41 pm Post subject: Free Fuel Flow |
According to the M14P 360HP manuals, at WOT the 360 HP M14 consumes
between 37 and 41 GPH. The 400 HP M14 will consume between 43-44 GPH at
WOT. I have also proven these numbers to be accurate for the 360HP
engine using a fuel flow instrument.
Dennis
On 4/9/2011 6:02 PM, n801bh(at)netzero.com wrote:
[quote] This will get you within a few gallons per hour for your fuel burn. On
Ben Haas
N801BH
culpspecial(at)yahoo.com Guest
Posted: Sat Apr 09, 2011 7:14 pm Post subject: Free Fuel Flow |
It has been my experience that at high cruise I burn about 15 GPH.
Most new M-14Ps are dynoed at 378 or so but you don't usually fly them at 100%. At the factory allowed 103% you are probably around 400 hp so I don't think there is a lot of difference in burn between the 360 and 400 engines.
During an airshow routine I figured about 5 gallons for 14 minutes. 103% for takeoff until the tail is up and then back to 95% until 3 or 4 rolls depending on wind conditions and after a turnaround working the power from 95% in the vertical back to 85% or a bit less on a downline. That is with the big MT 3blade. This is after close to 2000 hours behind the M-14P and 500 airshows.
I would be interested to see if someone could burn 28GPH.
All of our planes use -6 run through the cockpit fuel selector. I don't remember the exact number but a -6 under low psi will flow quit a bit of fuel.
Hope this help,
Steve
Culp's Specialties
www.culpsspecialties.com
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Sent: Sat, April 9, 2011 6:02:57 PM
Subject: Re: Free Fuel Flow
Ben Haas
N801BH
Posted: Sat Apr 09, 2011 7:50 pm Post subject: Free Fuel Flow |
360 HP consumes 41 GPH ??? ............ Wow,,, That's turbine fuel flows.. I guess you could if ya left the sump drains locked open . <G>
Ben Haas
N801BH
Posted: Sun Apr 10, 2011 3:24 am Post subject: Free Fuel Flow |
Don't believe me, believe the M14P maintenance manual. The information
comes directly from it.
Dennis
On 4/9/2011 10:44 PM, n801bh(at)netzero.com wrote:
[quote] 360 HP consumes 41 GPH ??? ............ Wow,,, That's turbine fuel
Ben Haas
N801BH
lacombr(at)nbnet.nb.ca Guest
Posted: Sun Apr 10, 2011 3:30 am Post subject: Free Fuel Flow |
Thanks Steve, it does help, it gives a good perspective on what to expect.
Rino
