rvg8tor
Posted: Wed Apr 20, 2011 11:59 am Post subject: Lightening up Z12 |
I am going to ask this question a different way. In Z12 there are 2 alternators, on plays a standby roll and will only produce power when the main alternator goes out or is turned off. Given that only one alternator operates at a time only one ammeter would be needed to monitor the electrical load coming from the alternator providing the power.
This reduces parts count; takes out a shunt and switch required to look at two shunts with on meter and or removes extra ammeter.
So does anyone see any flaws in this logic?
Cheers
_________________ Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor |
Posted: Wed Apr 20, 2011 4:57 pm Post subject: Lightening up Z12 |
the power.
That will work
rvg8tor
Posted: Fri Apr 22, 2011 10:50 am Post subject: Re: Lightening up Z12 |
Since I would like to share one shunt, the shunt would have to come after the ANL for the main alternator and the fusible link for the standby alternator. Is there any issue with the placement of the shunt before or after the wire protection? Attached is a drawing of the proposal. The connection between the shunt and ANL will more than likely be copper bar stock.
You can see the standby B lead fusible link attaches to the shunt along with the B lead from the main alternator.
Also can you think of a failure mode in which the main alternator might be putting out a low amount of power that would still trip the 13V set point of the standby regulator? I am trying to think if there is a failure mode in which both alternators would be putting out power.
Thanks for the help.
the power.
That will work
Bob . . . |
Description: |
 Download |
Filename: |
Electrical System - Power Distribution Shared Shunt.pdf |
Filesize: |
188.36 KB |
Downloaded: |
454 Time(s) |
RV-8A QB (Engine)
Posted: Fri Apr 22, 2011 1:02 pm Post subject: Lightening up Z12 |
At 02:50 PM 4/22/2011, you wrote:
Quote: |
the proposal.
You can see the fuseable link attaches to the shunt along wiht the B
What you show is fine.
rvg8tor
