aerobatics(at)aol.com Guest
Posted: Mon May 02, 2011 5:41 pm Post subject: windshield.... |
Im replacing the windshield one my kf2.. again. Cutting the lexan was never easy... any suggestions?
Thx
Dave
Kf 2 582 about 500 hours
Guy Buchanan
Posted: Mon May 02, 2011 9:01 pm Post subject: windshield.... |
On 5/2/2011 6:38 PM, aerobatics(at)aol.com (aerobatics(at)aol.com) wrote: | Quote: | | Im replacing the windshield one my kf2.. again. Cutting the lexan was never easy... any suggestions? |
Dremel with diamond wheel. The wheel's expensive, but boy does it make cutting plastic easy. Just make sure you go slow enough that the wheel doesn't get hot.
Guy Buchanan Normal Guy Buchanan 8 20 2010-09-24T17:53:00Z 2011-01-02T22:52:00Z 1 25 149 1 1 173 14.00 <![endif]--> 59 Clean Clean false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
Deceased K-IV 1200
A glider pilot too. |
Posted: Tue May 03, 2011 3:57 am Post subject: windshield.... |
Thanks! Off to Sears
Dave
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Tue May 03, 2011 4:22 am Post subject: windshield.... |
Hi,
I cut lexan door windows with an Olfa Knife, available at Home Depot. It worked great and the Olfa Knife has plenty other uses too. The cuts were mostly straight lines though.
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
Posted: Tue May 03, 2011 4:49 am Post subject: windshield.... |
Never heard of that.... will definitely check it out
Dave
lcfitt(at)sbcglobal.net Guest
Posted: Tue May 03, 2011 6:38 am Post subject: windshield.... |
Trimming windshield. I like to use tin snips - within about an eighth of an inch of the final line and finish up with an electric planer.
Lowell
From: aerobatics(at)aol.com (aerobatics(at)aol.com)
Sent: Monday, May 02, 2011 6:38 PM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: windshield....
Thx
Dave
msm_9949(at)yahoo.com Guest
Posted: Tue May 03, 2011 9:08 am Post subject: windshield.... |
Tin snips worked fine for me.
Marco Menezes N99KX
Model 2 582-90 C-Box w/clutch
Hersey, MI
--- On Mon, 5/2/11, aerobatics(at)aol.com <aerobatics(at)aol.com> wrote:
From: aerobatics(at)aol.com <aerobatics(at)aol.com>
Date: Monday, May 2, 2011, 9:38 PM
Thx
Dave
rexinator
Posted: Tue May 03, 2011 10:14 am Post subject: windshield.... |
It may not make as much difference with polycarbonate vs acrylic, but I
suggest heating the plastic ahead of your cuts or drilling with a heat
gun. The heat gun could be mounted so that it heats the work area just
before it is fed into the cutting blade or drill bit. It makes the cuts
so much easier as the plastic will be softer and much less prone to
fracturing as you cut or drill.
Just be very careful you don't get it too hot. Experiment with scrap first.
Rexinator
Model 2, 582
Colorado
On 5/2/2011 7:38 PM, aerobatics(at)aol.com wrote:
[quote] Im replacing the windshield one my kf2.. again. Cutting the lexan was
Thx
Dave
henrysfork1(at)msn.com Guest
Posted: Tue May 03, 2011 12:03 pm Post subject: windshield.... |
Tin snips work real well - but of course you will hear all kinds of horror stories to the contrary.
Dee
Model II
N345DY
Date: Tue, 3 May 2011 10:04:05 -0700
Subject: Re: windshield....
Marco Menezes N99KX
Hersey, MI
Thx
Dave
dholly
Posted: Wed May 04, 2011 8:56 am Post subject: Re: windshield.... |
I started with snips, moved to a Dremel tool with diamond blade, then ended up using a multi-function oscillating tool (Fein or Harbor Freight) with a steel half moon blade. The blade has small, closely spaced teeth and cut faster than the small diamond grit Dremel blade when set slow to avoid melting. Cut cleanly right along the line with excellent control and required little edge polishing. Did the front strut curves with a small drum sander in the Dremel.
_________________ -Kitfox III 582 Blue/C Grove Spring / Aerocet 1100 Amphibs
-Airdale Avid+ (project) TD / W.I.B. Gear |
clint_bazzill(at)hotmail. Guest
Posted: Wed May 04, 2011 4:24 pm Post subject: windshield.... |
I just had to add my 2 cents worth.
I have cut 3mm, 4mm and side windows, can't remember their thickness.
Marked lexan with pen. Cut with sabre saw.
Clint Model IV 912ULS since 1999.
[quote]http://www.matronics.com/Navigator?Kitfox-List
http://forums.matronics.com
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Thu May 05, 2011 2:46 am Post subject: Re: windshield.... |
| clint_bazzill(at)hotmail. wrote: | | Cut with sabre saw. |
Same here; I cut just off the line with a sabre saw, then sanded down to the line with a belt sander & dremel. I also used a plasticut file to remove any tool marks from the edges.
Posted: Thu May 05, 2011 6:40 pm Post subject: windshield.... |
Thank you to everyone ... lots of great tips... really appreciate it
Dave
