larkrv10(at)yahoo.ca Guest
Posted: Mon May 02, 2011 6:09 pm Post subject: fuel tank countersinks |
Hi all
I'm just about to countersink the tank skins to the rear baffle, and can't figure out why we are to leave every 10th hole untouched only to go back later and then complete the countersink and rivetting etc. Sounds like it has something to do with alignment???
I must be missing something. Can anyone explain?
Thx, Rick
#40956
Southampton, Ont
I
Neal.George(at)hurlburt.a Guest
Posted: Tue May 03, 2011 3:51 am Post subject: fuel tank countersinks |
Rick -
The tank skins are barely thick enough to accept the countersink, thus
leaving a thin, fragile hole edge that is easily damaged by the clecos
used to hold things in place. Leaving a number of holes with their full
thickness of metal and using those holes to align and clamp the
structure gives the builder a better chance of proper fit-up and final
assembly.
neal
william(at)gbta.net Guest
Posted: Tue May 03, 2011 4:58 am Post subject: fuel tank countersinks |
Rick, I know the instructions say to countersink, but I dimpled mine and
everything turned out perfectly. Dimpled the skins and the rear baffles.
Much faster, more uniform holes, etc.......
Just a thought.
From: "George, Neal Capt 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil>
Sent: Tuesday, May 03, 2011 6:41 AM
Subject: RE: fuel tank countersinks
Rick -
assembly.
neal
Posted: Tue May 03, 2011 5:03 pm Post subject: fuel tank countersinks |
Ahh...I knew there was a simple reason. Thx Neal
Rick
do not achive
--- On Tue, 5/3/11, George, Neal Capt 505 TRS/DOJ <Neal.George(at)hurlburt.af.mil> wrote:
From: George, Neal Capt 505 TRS/DOJ <Neal.George(at)hurlburt.af.mil>
Received: Tuesday, May 3, 2011, 11:41 AM
--> RV10-List message posted by: "George, Neal Capt 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil (Neal.George(at)hurlburt.af.mil)>
Rick -
assembly.
neal
Posted: Tue May 03, 2011 5:09 pm Post subject: fuel tank countersinks |
Bill, I like the way you think. Dimpling sounds like a great idea, far stronger. I can't see any reason to countersink either. I assume you had no trouble getting the rear baffle in place when you had the tank sealant applied?
Thx, Rick
#40956
Southampton, Ont
--- On Tue, 5/3/11, Billy & Tami Britton <william(at)gbta.net> wrote:
Subject: Re: fuel tank countersinks
Received: Tuesday, May 3, 2011, 12:54 PM
--> RV10-List message posted by: "Billy & Tami Britton" <william(at)gbta.net (william(at)gbta.net)>
Just a thought.
From: "George, Neal Capt 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil (Neal.George(at)hurlburt.af.mil)>
To: <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Subject: RE: RV10-List: fuel tank countersinks
[quote] --> RV10-List message posted by: "George, Neal Capt 505 TRS/DOJ"
Rick -
assembly.
neal
Posted: Wed May 04, 2011 2:11 am Post subject: fuel tank countersinks |
Sorry guys/Bill, I meant to say "no reason not to countersink".
Rick
Received: Wednesday, May 4, 2011, 1:04 AM
Thx, Rick
#40956
Southampton, Ont
--> RV10-List message posted by: "Billy & Tami Britton" <william(at)gbta.net>
Just a thought.
Rick -
assembly.
neal
Posted: Wed May 04, 2011 6:30 pm Post subject: fuel tank countersinks |
That is the exact reason Vans told me not to dimple is because of fitting the baffle between the skins/ into position after dimpled. I assure you, it's a non-issue. When dimpled, they still drop right in.
Sent: Wednesday, May 04, 2011 5:07 AM
Rick
--- On Wed, 5/4/11, Rick Lark <larkrv10(at)yahoo.ca (larkrv10(at)yahoo.ca)> wrote:
From: Rick Lark <larkrv10(at)yahoo.ca (larkrv10(at)yahoo.ca)>
Thx, Rick
#40956
Southampton, Ont
Just a thought.
| Quote: | --> RV10-List message posted by: "George, Neal Capt 505 TRS/DOJ"
Rick -
assembly.
neal
-----Original Message-----
Hi all
Thx, Rick
#40956
St; http://f= - List Contributionsp; &bsp;-->
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
| [quote]
