rv10flyer(at)verizon.net Guest
Posted: Tue May 24, 2011 10:19 am Post subject: fuel pressure sensor- Dynon specific |
What did Dynon say about this? Being I have a Skyview I am concerned about the reason for the oscillating.
Thanks!
Pascal
Sent: Tuesday, May 24, 2011 10:38 AM
Subject: Re: fuel pressure sensor
Don't know if it's the same sensor, but my one from Dynon lasted about 25 hours, before it started "oscillating" with the boost pump off. Replaced it, and the problem was fixed... for about 5 hours. Seeing the same issue again.
On Tue, May 24, 2011 at 10:17 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
| Quote: | I have a GRT sensor which is occasionally providing a reading of 38 psi which puts me into the out of limits condition for the Chelton displays. Normal reading is about 29 psi. part total time is about 450 hours. anyone else had sensor problems? I carry a replacement in the tool/parts box so I can change it but trying to confirm that it needs to be replaced. Engine continues to perform properly.
ttp://forums.matronics.com
Rob Kochman
RV-10 Flying, Phase 1
Woodinville, WA
http://kochman.net/N819K
Posted: Tue May 24, 2011 2:26 pm Post subject: fuel pressure sensor- Dynon specific |
I have never had a problem with the fuel pressure or oil pressure sensors, with Dynon or any other system. Dynon gets its ground through the block bolted to the firewall, so it that is somehow isolated or not making a good ground, that could possibly be causing it.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On May 24, 2011, at 2:14 PM, Pascal wrote:
[quote] What did Dynon say about this? Being I have a Skyview I am concerned about the reason for the oscillating.
Thanks!
Pascal
Rob Kochman
Woodinville, WA
