davidlewendon(at)me.com Guest
Posted: Fri May 27, 2011 11:58 pm Post subject: Filser Radio problems |
I have a Filser ATR 600 VHF Com plus a separate Filser Mode S
Transponder. I am experiencing difficulties in transmitting and
although I can hear various ATC centers from a reasonable distance of
20 to 30 miles out I cannot get them to hear me until I am only 6 or 7
miles away.
My Europa does not have an external antenna and having looked in the
rear fuselage section there appear to be two coax type cables. One
goes to a black metal box approximately 4 inches long and 3/4 of an
inch square that is fixed to the upper side of the fuselage (about the
ten o clock position). The other cable disappears into the tail section.
There is a small unpainted metal antenna about 2 inches long
protruding from the lower fuselage but this must be too short for a
VHF radio and does not have the small ball on the end like a
transponder aerial would have.
BTW, I have not checked the transmit button yet for a good connection.
Any clues pleas?
David
budyerly(at)msn.com Guest
Posted: Sat May 28, 2011 1:13 pm Post subject: Filser Radio problems |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> David,
Perhaps it is best to check the following in this order for a field check:
First check and ohm out your radio connections and coax attachment to your antenna. Check out the coax that the center wire and outer shield have no continuity.
If the antenna is buried in the rear, do the following:
Build a 10 foot coax cable jumper. Install your coax jumper lead to the radio back.
Beg, borrow or buy a standard VHF metal antenna with a ground plane, or make a ground plane from aluminum and bolt it too the antenna and connect to the ground. Place the antenna on a bench
near the aircraft. OR
I have an Advanced Aircraft Electronics VHF - 5T spare in my shop for this purpose.
The coax connector attached to this antenna needs no ground plane and is made from carbon fiber and wire. It is just like the tape antenna in principal, but I have yet to find a better easier to install antenna, but that is an opinion, because all properly built and installed antennas should be nearly equal.
To best test your integrity of the com system.
If the intercom is loud and clear then the intercom to jacks are OK.
The newer radios have transmit key indicators as does a separate intercom which may also be in your system. Press the mic button and look. If the transmit indicator appears, the hookup is OK as the mic hi position is connecting to ground for the transmit signal. If the ground used for the mic button is hooked up outside the back of the radio, you may have a poor and noisy ground or ground loop.
Please check your electrical continuity and circuit output using the temporary antenna by pushing the com and giving a test count and observe the power meter then check your primary antenna. If you don't have a power meter, don't despair. compare the output transmission using a handheld or other nearby radio.
If it is the antenna, it is time to go shopping.
Again if the antenna is the problem, the fastest, easiest to install, high performance antenna is the VHF 5T available through Aircraft Spruce.
An excellent position if you have no access to the tail, is to install it just behind the baggage bay as close to vertical as possible. Works great even with a little curve.
As for the short antenna, that is most likely your Transponder antenna.
Again, test its continuity and ground plane as the short antenna has a ground plane requirement for the whip antenna of about an eight inch disk. Your ground plane may not have been installed.
Again Advanced Aircraft Electronics has an antenna if yours does not work.
The small box may be a radio switching box. It may have been used for Nav and Glide slope switching if there is a horizontal antenna or a com switcher if the ELT antenna was also hooked to the com antenna. Hard to tell without tracing out your com and reading the part number on the box.
Bud Yerly
Custom Flight Creations, Inc.
www.customflightcreations.com
(813) 653-4989
jimpuglise(at)comcast.net Guest
Posted: Sat May 28, 2011 1:43 pm Post subject: Filser Radio problems |
David-
I had an identical problem a few years ago. I had blown the final in my transmitter. The final transistor is relatively powerful and what permits you to transmit some distance. I was getting about 2 milliwatts output from the driver and could be heard for about 3 miles. Replacing the final transistor was the fix. If you can beg, borrow, or steal one, a wattmeter with a dummy load will tell you if that is the case. Simpler than all the testing, if you can get to the back of the transmitter, put an SWR bridge in the line. If it is an antenna problem, the SWR will be quite high, probably over 2/1. If you know someone who is a radio amateur they may be able to help you with both tests. They are very simple and can be done in five minutes or so. Failing that, I'd construct a tape dipole as described in the manual and hang it outside the plane. If you can both transmit and receive off it, the antenna in the airplane is your problem. The tape dipole aft of the baggage compartment will work just fine if you need to replace the antenna.
Jim Puglise, Punta Gorda, FL
Posted: Sun May 29, 2011 2:16 am Post subject: Filser Radio problems |
On 05/28/2011 11:09 PM, Bud Yerly wrote:
| Quote: | First check and ohm out your radio connections and coax attachment to
have no continuity.
All too complicated and not necessary. Just borrow an SWR-meter, and see
what it says. Broken wires, shorts, resonance problems, everything shows
up with this simple test.
There are many radio amateurs, find one and he probably loves to look at
the installation of a real airplane.
If there is anything else than the Europa recommended halve wave antenna
in the tail closeout, I would scrap it and arrange such a halve wave
antenna. Contradictory to common believe fed by marketroids, there is
nothing that beats a simple halve wave dipole for this application. No
antenna can have any gain over a dipole without introducing losses in
some area's. It is just like a light bulb, any gain you derive with
reflectors and lenses will introduce dark spot in other directions. A
half wave is close to omnidirectional and only has two small "dark
spots" straight up and straight down. Fortunately if you are overhead an
ATC facility the "dark spot" is of no consequence as you are pretty
close anyway.
There is another reason to stay with a dipole: A dipole has a certain
impedance and it is exactly this impedance (50 ohms) that became the
standard for the coax and output of the transmitter. Of course this is
no coincidence as the manufacturers know that the dipole is the best
solution. Other antennas might have a different impedance, need a
matching network (often built in and invisible to the user), and often
this matching network (consisting of coils and capacitors) breaks down,
causing all sorts of problems.
Just my 2 cents,
Frans
Posted: Sun May 29, 2011 2:18 am Post subject: Filser Radio problems |
On 05/28/2011 11:40 PM, jimpuglise(at)comcast.net wrote:
| Quote: | Simpler than all the testing, if you can get to the back of the
If you know
tests.
Oops. I should read the entire list before answering something.
Frans
Posted: Sun May 29, 2011 3:33 am Post subject: Filser Radio problems |
Thanks for all the tips folks.
I will track down an SWR meter and check out the system.
I will let you know how I get on.
BW
David
On 29 mai 11, at 12:13, Frans Veldman wrote:
> shield
> have no continuity.
see
shows
look at
antenna
overhead an
close anyway.
down,
Just my 2 cents,
Frans
Posted: Mon May 30, 2011 4:00 pm Post subject: Filser Radio problems |
Guys,
I guess I really have a dumb SWR meter in comparison to yours. It allows me to measure if my antenna is tuned to the freq (all our antennas bought on the market are tuned, only handmade ones aren’t and they are close (probably within 4-5% if you follow the instructions).
Radio systems work best when the antenna system's impedance
matches the transmitter's output impedance as closely as possible.
The meter's standing wave ratio (SWR) function helps you trim your antenna
to the precise length you need for the maximum transmitted power.
The meter's field strength function helps you position your antenna for
the best coverage and determine the effectiveness of changes you make to
your antenna, antenna cable, and transmitter. We already know the tail is a superb place in the Europa.
If you have a radio that you suspect a low power or poor transmit but can receive OK, it seems that one can check with an SWR but you will still have to get another antenna and compare if the installed antenna is not working. Plus, you must get to the back of the radio and hook up a jumper get the meter hooked in anyway. The SWR is not going to tell me anything other than good or bad on the installed antenna, so get a good antenna off the shelf and compare is what works fast and easy.
Finally, if you suspect the radio is bad, (you should have bench checked it, but what the heck¸ it is a new radio and my experience in 12 panels they all worked), so if you suspect the radio, you have to bench check it anyway. An Ohm meter will tell you if you have a bad cable and the quick disconnect com lead at your panel back is your junction to the spare antenna and you have your quick and dirty check.
Check your dials if you want, but it isn’t going to be any faster. That’s why I have the spare antenna and build my panels to pop out fast. My com 25 pin D sub connection from the panel to the airframe can be hooked to a jack for a separate com check in minutes right on the bench. By opening up the firewall access hole, and hooking to the backup antenna is the quickest way to satisfaction.
Bud
Posted: Tue May 31, 2011 2:14 am Post subject: Filser Radio problems |
On 05/31/2011 01:57 AM, Bud Yerly wrote:
| Quote: | I guess I really have a dumb SWR meter in comparison to yours.
No, any SWR will do.
| Quote: | It
That's one of the things it can do. If the cable is shorted or broken,
the impedance will show up as zero or infinite ohms, so it will display
a severely out of tune situation.
| Quote: | If you have a radio that you suspect a low power or poor transmit but
is not working.
You don't have to do that, if the SWR shows up OK, you can be pretty
sure that the antenna is working and the cable is OK.
Frans
