NYTerminat(at)aol.com Guest
Posted: Wed May 10, 2006 8:46 pm Post subject: Maintainance Schedule for 912S |
List
Am I missing something, I don't seem to be able to find how often Rotax recommends changing oil and filters on their 912S.
Bob Spudis
N701ZX / 912S 36hrs
rholder(at)avnet.co.uk Guest
Posted: Thu May 11, 2006 12:02 am Post subject: Maintainance Schedule for 912S |
NYTerminat(at)aol.com wrote:
| Quote: | Am I missing something, I don't seem to be able to find
their 912S.
Here the recommendation is at
25, 50, 100, 150, 200 hours, but the 50 hour interval
should be reduced to 25 hours if more than 30% Avgas has
been used for those 25 hours.
Always change the oil filter when you change the oil !
Richard
G-OWWW High Cross
Thom Riddle
Posted: Thu May 11, 2006 2:24 am Post subject: Maintainance Schedule for 912S |
Rotax recommends 50 hours between oil and filter changes if you use
aviation fuel (100LL) for more than 30% of the time and 100 hours if
you use 100LL less than 30% of the time. Even though we use 100LL less
than 30% of the time, we change our oil and filter every 50 hours.
Just as important, if not more so, is the type of oil you use. Like
many motorcycles, the 912 uses the same oil supply for both the engine
and gearbox so it MUST HAVE GEAR ADDITIVES. It also has a clutch so it
MUST NOT have FRICTION MODIFIERS. If you use a lot of 100LL you MUST
NOT use FULL SYNTHETIC oil. Pure synthetic oils do not scavenge the
lead.
I have used California Power Systems AV-9 formulated especially for the
912 but shipping cost is so high, we will be using Pennzoil Motorcycle
Oil in the future, which is one of the oil Rotax has tested and
recommends (semi-synthetic). It is available here locally from the
distributor without a hefty shipping charge.
See:
Service Instruction-18-1997 R5 at www.rotax-owner.com/sdocs.htm
Thom in Buffalo
FAA Powerplant Mechanic
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Bob Griffin
Joined: 22 Jan 2006 Posts: 34 Location: Slingerlands,NY
Posted: Thu May 11, 2006 3:33 am Post subject: Maintainance Schedule for 912S |
Hi Bob & gang, 1st oil change-- 25 hrs. There after ---- auto fuel plugs & oil-100 hrs.
100 LL plugs & oil- 50 hrs.
Fly Safe
Bob Griffin
upstate NY
_________________ Fly Safe
Bob Griffin
Slingerlands, NY |
Posted: Thu May 11, 2006 7:04 pm Post subject: Maintainance Schedule for 912S |
Thanks for the reply's, where did everyone get their info from? It doesn't appear to be in the Rotax Maintenance Manual.
Bob Spudis
N701ZX / 912S 36 hrs
In a message dated 5/11/2006 7:34:15 A.M. Eastern Daylight Time, Airgriff2(at)aol.com writes:
| Quote: | Hi Bob & gang, 1st oil change-- 25 hrs. There after ---- auto fuel plugs & oil-100 hrs.
Fly Safe
Bob Griffin
upstate NY
Thom Riddle
Posted: Fri May 12, 2006 3:30 am Post subject: Maintainance Schedule for 912S |
From the Rotax Line Maintenance Manual. Here is a link to where you can
download it and other Rotax information.
http://www.kodiakbs.com/tiintro.htm
Thom in Buffalo
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun May 14, 2006 11:34 am Post subject: Maintainance Schedule for 912S |
Thom
Thank you for the referenced info, I am printing out the 106 pages as I type this. Thanks to all that replied regarding the oil changes.
Has anybody been mixing 87 Mogas with 100 low lead to get the octane needed for the 912S and still trying to cut down on the lead content?
Bob Spudis
N701ZX 701/912S 40 hrs
In a message dated 5/12/2006 7:31:05 A.M. Eastern Daylight Time, jtriddle(at)adelphia.net writes:
| Quote: | --> RotaxEngines-List message posted by: Thom Riddle <jtriddle(at)adelphia.net>
Thom in Buffalo
