		rvg8tor
				 Posted: Tue Jun 07, 2011 7:31 pm    Post subject: AFP Injection and RV-8A |
				I am trying to sort out my mixture and throttle cables.  If you have a RV-8A (nose gear) and Air Flow Performance fuel injection, that is vertical induction please message me.
 The exhaust hangers (Vetterman cross over) and the supports of the engine mount make this a very troublesome puzzle.
 Thanks in advance.
 Cheers
  |  | - The Matronics RV8-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor |
		Terry Watson
  Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
				 Posted: Tue Jun 07, 2011 8:05 pm    Post subject: AFP Injection and RV-8A |
				Here us a link to some photos of what I did a few years ago for that same
 combination. I seems to work pretty well, but then again it has never been
 in the air either: http://tcwatson.zenfolio.com/p288537335
 Terry
 RV-8A project - stalled
 Seattle
		rvg8tor
				 Posted: Wed Jun 08, 2011 6:33 am    Post subject: Re: AFP Injection and RV-8A |
				Terry,
 It looks like you came up with the solution I am getting too.  I assume you had the AFP unit sent back to have the mixture control rotation revered to make yours work.  My unit came with the rotation from ICO to Rich being Clockwise and it needed to be revered to make the control work with where the cable needed to be located.
 Thanks for the pictures.  You are the first -8A using both Vert Ind and AFP FI I have seen.
 Cheers
RV-8A QB (Engine)
		Terry Watson
				 Posted: Wed Jun 08, 2011 10:41 am    Post subject: AFP Injection and RV-8A |
				I don't recall having the mixture control rotation reversed. But then it has
 been quite awhile - and maybe I have it backwards!
 Terry
				 Posted: Wed Jun 08, 2011 3:27 pm    Post subject: AFP Injection and RV-8A |
				My install is very similar to Terry's, except my mixture line is more
 vertical.  I fabricated the brackets in place and remember I had to use a
 couple of pieces of angle riveted together to get the right setup on the
 mixture.  I was able to use the control cable length by Van's.  I also
 remember having a nice pile of aluminum scraps and dust from various trials
 and errors.  You can use some light aluminum sheet to mock up the brackets,
 then fabricate from few pieces of 1/8" x 2" x 2" or so angle.  Don't worry
 about the big size as you will trim off the excess anyway.
 Carl Froehlich
 RV-8A (650 hrs)
 RV-10 (almost ready for fuselage paint)
		rvg8tor
				 Posted: Wed Jun 08, 2011 4:06 pm    Post subject: Re: AFP Injection and RV-8A |
				Carl & Terry,
 Thanks for the inputs, it is alway nice to know you are on the right track.  In the photo you can see prototype #1.  I basically went the straight route, this seems to give the best clearance between the exhaust and the mount support.  I will put a heat shield on the exhaust and will watch closely, I am a little worried since I don't know how much the engine moves in this area, finding the right clearance seem to be a little of a crap shoot.
 Cheers
RV-8A QB (Engine)
				 Posted: Wed Jun 08, 2011 4:33 pm    Post subject: AFP Injection and RV-8A |
				Nice work.
 I think I was one of the few people to do the AFP/vertical draft/RV-8A
 install - killing four or five weekends in the process.
 As I mentioned I ran the mixture cable more vertical, on the inside of the
 interfering engine mount pipe (you have yours on the outside).  This kept it
 away from the exhaust and I didn't need to use the spacer at the end of the
 control cable like you have.  This did require re-clocking the AFT throttle
 body mixture control arm.  Just a different way to do it.
 Carl
		rvg8tor
				 Posted: Wed Jun 08, 2011 11:00 pm    Post subject: Re: AFP Injection and RV-8A |
				Carl,
 My first idea was to run the mixture inside the support from what you see in the above picture but once I had the exhaust hung, the hanger gets in the way, this drove me to move it to the outside even though this gets it close to the exhaust pipe.  You can just see the black tube of the hanger behind the cleco in the above picture.  I just can't see how to hang the exhaust so there is not something in the way of the cables.  My throttle cable gets a little close to the hanger on the other side.
 I even gave consideration to using and elbow to make the fuel control horizontal, just so I have better options for the control cables but his would require more money and parts and I would have to send the fuel control back to AFP to have the fuel inlet and out let moved.  It was already a $150 evolution to reverse the mixture throw.
 Do you have the cross over exhaust?  If so how did you hang the tail pipes, if you have pictures that would be greatly appreciated.
RV-8A QB (Engine)
