n223rv(at)wolflakeairport Guest
Posted: Sun Jun 19, 2011 9:05 am Post subject: Nose wheel pant removal question |
How are most people removing the nose wheel pants? By removing the 2 Allen head bolts and keeping the brackets on the pants, or removing the 8 screws and leaving the brackets on the nose wheel? I've seen people do both...
rene(at)felker.com Guest
Posted: Sun Jun 19, 2011 9:33 am Post subject: Nose wheel pant removal question |
I remove the two Allen head bolts.
Rene' Felker
N423CF
801-721-6080
Lew Gallagher
Posted: Sun Jun 19, 2011 9:42 am Post subject: Nose wheel pant removal question |
Hey Michael,
Since I've had lots of practice here lately, this is what I've done. I
remove the 2 Allen head bolts and keep the brackets on. But with
modifications. I've put the stainless Helicoil threads in the aluminum
forks so that the Allen bolts don't strip them out, replaced the original
Allen bolts with ones 1/2 inch longer and use spacers so that the head
extends beyond the pants so that the tow bars don't damage the pants. And
I've replaced the two small washers on each side of the axel with a
flattened out lock washer (it's a tiny bit thicker than the two thin
washers) topped with a larger outer diameter washer. This makes sliding the
brackets on the axel MUCH easier with the better clearance and the larger
washer on top keeps the bracket from sliding off when first aligning the
brackets.
I've been renting out the Helicoil kit for $5 plus shipping to anyone
interested that doesn't want to buy the whole kit (it's pricey) for just
those two threads.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
dmaib(at)mac.com Guest
Posted: Sun Jun 19, 2011 10:52 am Post subject: Nose wheel pant removal question |
Much easier to remove the 2 allen head bolts and leave the brackets
attached to the pants. I've done it both ways.
David Maib
40559
Flying
On Jun 19, 2011, at 1:00 PM, Michael Kraus wrote:
<n223rv(at)wolflakeairport.net>
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sun Jun 19, 2011 11:56 am Post subject: Nose wheel pant removal question |
I use the Allen bolts. Only 30 hours though.
On Jun 19, 2011, at 11:00, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
bruce1hwjohnson(at)yahoo. Guest
Posted: Mon Jun 20, 2011 9:04 am Post subject: Nose wheel pant removal question |
Hi Lew, When its available I would like to rent the kit. I was thinking something had to be done with the aluminum and yours sounds like a great idea.
Bruce 151BJ 53 hrs
Sent: Sunday, June 19, 2011 10:40 AM
Subject: Re: Nose wheel pant removal question
--> RV10-List message posted by: "Lew Gallagher" <lewgall(at)charter.net (lewgall(at)charter.net)>
Hey Michael,
Since I've had lots of practice here lately, this is what I've done. I remove the 2 Allen head bolts and keep the brackets on. But with modifications. I've put the stainless Helicoil threads in the aluminum forks so that the Allen bolts don't strip them out, replaced the original Allen bolts with ones 1/2 inch longer and use spacers so that the head extends beyond the pants so that the tow bars don't damage the pants. And I've replaced the two small washers on each side of the axel with a flattened out lock washer (it's a tiny bit thicker than the two thin washers) topped with a larger outer diameter washer. This makes sliding the brackets on the axel MUCH easier with the better clearance and the larger washer on top keeps the bracket from sliding off when first aligning the brackets.
I've been renting out the Helicoil kit for $5 plus shipping to anyone interested that doesn't want to buy the whole kit (it's pricey) for just those two threads.
Later, - Lew
Lew Gallagher
Posted: Mon Jun 20, 2011 1:46 pm Post subject: Nose wheel pant removal question |
Hey Bruce,
Private email me your address and I'll send it on it's way.
Later, - Lew
