craigtxtx(at)yahoo.com Guest
Posted: Sat Jun 25, 2011 6:03 am Post subject: Fixed pitch to constant speed |
I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop.
Craig Gallenbach
Eastover, NC
RV8-A, N184CG 195hrs
fastpilotrv8
Posted: Sat Jun 25, 2011 6:33 am Post subject: Fixed pitch to constant speed |
I have a RV8a with a IO-360 200hp which is a little heavier than your engine plus I have constant speed prop and have been flying it since 2002. That being said I do keep 25 lb. of lead shot in the aft baggage compartment and a few tools which keeps the elevator pretty even or level in flight thus creating less drag. When landing it also helps with a lot less trim. I have confess my best landing are when I have a passenger in the rear seat and nothing in the aft baggage area
Dane Sheahen
RV8a
On Jun 25, 2011, at 9:01 AM, Craig Gallenbach wrote:
[quote]I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop.
Craig Gallenbach
Eastover, NC
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
Posted: Sat Jun 25, 2011 6:50 am Post subject: Fixed pitch to constant speed |
Craig,
Do you have your battery in the back?
I have an IO-360 200 Hp / Hartzell BA CS prop (great combination) and have no issues flying solo with full fuel or near empty and no weight in the back.
One note I have dual G3X and back up EFIS so I suspect my panel is lighter than a 10 year old build with steam gauges.
Robin
RV-4 Sold
RV-6A Sold
RV-10 225 Hours
RV-8A 30 Hours
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of AOL
Sent: Saturday, June 25, 2011 7:31 AM
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Re: RV-List: Fixed pitch to constant speed
Dane Sheahen
RV8a
Craig Gallenbach
Eastover, NC
RV-List Email Forum -[/b]_-= Use the Matronics List Features Navigator to browse[/quote][/b][/quote] Day Browse, Chat, FAQ,[/b] [/quote]012 m">http://forums.matronics.com[/b] [/quote]34 -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]5
Posted: Sat Jun 25, 2011 8:13 am Post subject: Fixed pitch to constant speed |
Battery is on the firewall. CG with me and no fuel is 79.47. I am hoping to do this with minimum changes such as having to move the battery.
Craig
On Jun 25, 2011, at 10:47 AM, Robin Marks <robin(at)PaintTheWeb.com (robin(at)PaintTheWeb.com)> wrote:
Craig,
Robin
RV-4 Sold
RV-6A Sold
RV-10 225 Hours
RV-8A 30 Hours
From: [url=mailto:owner-rv-list-server(at)matronics.com]owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)[/url] [mailto:[url=mailto:owner-rv-list-server(at)matronics.com]owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)[/url]] On Behalf Of AOL
To: [url=mailto:rv-list(at)matronics.com]rv-list(at)matronics.com (rv-list(at)matronics.com)[/url]
Subject: Re: Fixed pitch to constant speed
Dane Sheahen
RV8a
Craig Gallenbach
Eastover, NC
Day Browse, Chat, FAQ,01 m">http://forums.matronics.com2 =======================3
dickseiders(at)gmail.com Guest
Posted: Sat Jun 25, 2011 8:21 am Post subject: Fixed pitch to constant speed |
Craig, I had an RV6A with a Hartzell Constant Speed. I believe it added 40 to 50lbs on the nose. That wasn't a problem for the 6A. Can't speak for the 8. The Hartzell is a great prop (supplied direct from factory by Van's). It performed perfectly for over 500 hrs and is still flying as before. (sold 6A last yr). If you are considering a Whirlwind check it out closely as I have a friend who owned an 8 and could never get his to work as expected. That doesn't mean it's not a good cons.spd. product. It means just what I said.
Dick seiders
On Sat, Jun 25, 2011 at 10:01 AM, Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)> wrote:
[quote] I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop.
Craig Gallenbach
Eastover, NC
t="_blank">http://www.matronics.com/Navigator?RV-List
| [b]
