roee
Posted: Mon Feb 28, 2011 2:32 pm Post subject: Toggle switch keyway convention: up vs. down |
This is a question for Bob Nuckolls as author of the AeroElectric Connection:
In the chapter on switches, it is stated that "for most applications, switches are mounted with bushing keyway oriented UP in the panel." (Page 11-16)
However, looking at various other sources, including several switch manufacturers' datasheets as well as switch-related mil specs, it seems that the common convention is actually to mount switches with the keyway oriented down.
And another small clue in support of the keyway down convention is the most basic of all switches, the S700-1-2 described in the AeroElectric Connection itself. The action is OFF on the keyway position and ON on the opposite position. Common functional convention for on/off switches is ON-up / OFF-down (I don't think that's in dispute, right?). So to conform to this convention in switching a load using a S700-1-2 switch, it would have to be oriented keyway down.
So I'd like to understand the apparent discrepancy in conventions, keyway up vs. down. Now, I understand that either way it's just a matter of convention and is otherwise pretty much arbitrary. But if there really is a reason that I'm not aware of to favor keyway up, then, well, I'd like to be made aware of it so I can make the most informed decision when choosing a convention for my panel. Bob, are there such factors in favor of keyway up?
-Roee
tim2542(at)sbcglobal.net Guest
Posted: Mon Feb 28, 2011 5:05 pm Post subject: Toggle switch keyway convention: up vs. down |
I just ran into this myself after having my panel cut out on a CNC machine with all the antirotation tabs cut into the top of the hole. Now I guess I'll have to replace all my 1-2 switches.
On Feb 28, 2011, at 2:32 PM, "roee" <roee(at)kalinskyconsulting.com> wrote:
-Roee
http://forums.matronics.com/viewtopic.php?p=332328#332328
mmayfield
Joined: 09 Oct 2009 Posts: 40 Location: NSW Central Coast, Australia
Posted: Mon Feb 28, 2011 7:59 pm Post subject: Re: Toggle switch keyway convention: up vs. down |
Interesting question, and from my own research it seems a bit like "horses for courses" - the keyway may need to be up or down depending on your use of the switch. Eg, I have a panel plan with the 2TL1-50 switch in it for a boost pump/prime switch. The momentary action is for the prime, which will be in the "up" position, which is also the keyway position. The "off" position is opposite keyway. So the keyway must be orientated up.
On other switches I have planned like the 2TL1-10, the position of the keyway won't matter. As long as the right terminals are connected, they'll work just as intended. However on a 1TL1-2 or equivalent, the keyway will clearly have to be orientated down.
I would take "keyway conventions" with a grain of salt!
_________________ Mike |
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Tue Mar 01, 2011 6:22 am Post subject: Re: Toggle switch keyway convention: up vs. down |
You can't get closer to the Military Industrial Complex than Eaton, and they publish this bulletin:
http://www.ee-usa.com/ProductCatalogs/Eaton/eatonXT.pdf
You will notice that no Mil-standard is called out, but they lean heavily towards "key down". Their ST switches are "key-down-off"
True, they offer plates in either orientation, but they offer switches only one way...key-down-off. This also helps shed dirt-water, when you think about it.
The issue is settled: KEY-DOWN-OFF
Sorry, Bob.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
BobsV35B(at)aol.com Guest
Posted: Tue Mar 01, 2011 7:46 am Post subject: Toggle switch keyway convention: up vs. down |
Good Morning Eric,
Not quite so simple!
When I was making a new panel for our Piper Pacer, I wanted to make all keyways the same so that I could do all the locking holes on the first machining pass.
I was using a whole pacel full of Klixon 7274 circuit breakers and I wanted the amperage listing to be right side up. That required that the keyway be on top. I was able to wire the switches so they worked in that orientation so all seemed well. Unfortunately, I needed to install a different design circuit breaker, but it was made by the same manufacturer. Would you believe that in order to have the amperage number right side up the keyway had to be down? On my most recent panel rebuild, I made all of the electrical switch and circuit breakers so that the keyways could go either way. Doubled the work of drilling locking pin holes, but it was consistent and easy to change the orientation of the CBs when needed. There is NO standard! Not even within one manufacturer's design department.
Happy Skies,
Old Bob
In a message dated 3/1/2011 8:27:02 A.M. Central Standard Time, emjones(at)charter.net writes:
| Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
Sorry, Bob.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
JohnInReno
Posted: Tue Mar 01, 2011 8:24 am Post subject: Toggle switch keyway convention: up vs. down |
I just cut anti-rotation tab holes top and bottom. They are covered by
the switch plates and no key orientation issues. FYI - The pull-able
breakers seemed to require key way up.
On 2/28/2011 5:01 PM, tim2542(at)sbcglobal.net wrote:
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
Posted: Tue Mar 01, 2011 8:56 am Post subject: Toggle switch keyway convention: up vs. down |
Thanks John, I'm not using holes, I had the key cut into the switch hole, so that won't work. But it's no big deal, I just need to use a different switch.
On Mar 1, 2011, at 7:15 AM, John Morgensen <john(at)morgensen.com> wrote:
I just cut anti-rotation tab holes top and bottom. They are covered by the switch plates and no key orientation issues. FYI - The pull-able breakers seemed to require key way up.
> Tim
> Sent from my iPhone
roee
Posted: Tue Mar 01, 2011 10:22 pm Post subject: Re: Toggle switch keyway convention: up vs. down |
Bob's reply somehow ended up in a separate duplicate thread, so I'm re-posting it here:
| nuckolls.bob(at)aeroelect wrote: | | Quote: | | I would take "keyway conventions" with a grain of salt! |
It's been about 15 years since I did much writing
about switches but I think the context under which
keyways are oriented has become a bit muddled.
Most switches are symmetrical . . . they function
the same no matter which side the keyway faces.
Further, the right and left sides can be interchanged
with no observable differences in functionality.
When we began to study the application of progressive
transfer switches I published drawings with numbered
terminals to assist the neophyte technician in getting
wires on the right terminals the first time. I discovered
that the way Microswitch and Carling built their progressive
switches was not the same. I had to publish this piece to
make folks aware of the differences:
http://www.aeroelectric.com/articles/Carling_Micro/Carling_Micro.pdf
. . . right and left hand columns were functionally
swapped between the two brands. In later years,
I think Carling swapped their progressive transfer
switches to conform to what the mil-spec guys
were doing.
Microswitch had numbers molded into their switch
housings as did the other high-end suppliers. So
I adopted THEIR convention for speaking to terminal
' numbering versus functionality.
Once you venture out of the purely symmetrical
world by adding spring loading to one side (or
single pole switches with only two terminals)
then there is risk that the desired functionality
cannot be achieved with the keyway oriented any
particular direction.
This is one reason why I've always recommended
that keyway engagement washers (shipped on all
products offered by AEC and I think B&C) . . .
be used on the BACK side of the panel. This way,
the hole in the panel for the keyway engagement
washer can be under a switch labeling placard . . .
or be so shallow that it does not penetrate the
panel. This allows one to have them above, below
or even changed after initial installation
causes one to discover the need to change it.
[img]cid:.0[/img]
Speaking of 'conventions' . . . you'll note
that the panel tab and keyway tabs are on
the same side of this locking ring. But
I've seen them on opposite sides too.
So the premise of this tread is correct, there
are no industry-wide "conventions" for marking,
functional orientation, or installation of
switches. There ARE standards . . . many of
them mil-specs that speak to widely adopted
configurations. But it's a free-market decision
by designers and manufacturers as to how
their particular product comes into the
marketplace. In the case of switches,
one would do well not to stray far from
what the majority of your competitors are
doing . . . a Croatian market street
vendor will find himself at a decided
disadvantage hawking wares in Swaheli.
Bob . . . |
roee
Posted: Tue Mar 01, 2011 10:25 pm Post subject: Re: Toggle switch keyway convention: up vs. down |
Thanks Bob et al for the responses. I figured that would probably be the case -- the keyway up recommendation in the AEC being for some historical reasons and nothing more. Glad to have that confirmed. So for my panel I think I will go with keyway down for switches, as that does seem to be the more common convention in the mil specs and industry-wide.
Just a couple of general comments on other points raised in the responses:
In cases where the choice is technically arbitrary, I do think that there's value in following standard conventions in that it helps minimize possible confusion during assembly and future maintenance. All things being equal, where an industry-wide convention exists, whether formal or informal / de facto (e.g. keyway down, I think we've now established), then that would be the default first choice. Barring that, defining and adhering to a convention for the design (e.g. either all keyway down or all keyway up for the entire aircraft) would be the next best thing. And finally, having a mix-and-match hodge-podge throughout would be the least desirable, though granted, occasional well-justified exceptions to a convention may still exist.
It also behooves us, when possible, to select components during the design phase that adhere to industry standards and conventions. Doing this maximizes our ability to source spare parts in the future, including drop-in compatible products from alternate sources. And for that reason, as has been pointed out, it also behooves manufacturers to design their products in adherence to such standards and conventions, as they make them more appealing to us in our component selection. We've seen that not all switch (and CB) manufacturers and product lines meet that criteria, and I would factor that into my component selection process.
Thanks again,
-Roee
mathewdisoza
