jbr79r(at)yahoo.com Guest
Posted: Sat Jul 02, 2011 12:38 pm Post subject: power line interferances |
Hi Bob
I have talked to you before about my needing to move the batteries in my Glasair 111 from the firewall to behind the baggage compartment. My latest problem with this conversion is the routing of the 2 #2s and 2 #4s. To run down the center console there are a lot of things running in that area, but there may be enough room. The other option is to go under the wing, but that has it's problems as well. There is minimum room between the bottom of the wing and the belly panel, and a VOR antenna is in the way. My main question is: Are there potential problems I need to factor into the equation as to where these big wires run in relationship to the other wires and antennas. Any suggestions or ideas.
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Posted: Sat Jul 02, 2011 1:34 pm Post subject: power line interferances |
At 03:35 PM 7/2/2011, you wrote:
| Quote: | Hi Bob
Why two #4. The two batteries can share a single
#2 ground.
| Quote: | To run down the center console there are a lot of things running
Run them all together. There are no proximity issues
with respect to other wires/accessories.
