tomblejwas(at)yahoo.com Guest
Posted: Fri Jul 08, 2011 1:53 pm Post subject: Viking Engine |
I have ordered a Viking Engine, which is a Honda Fit conversion. Anyone using this engine? I've watched the installation video and I'm impressed with the completeness of the conversion. Jan Eggenfellner has included some installation hardware, like a machined holder for the dual fuel pumps, which I find an improvement over what I've seen for UL installations. I'd really like to hear of any first-hand experience with the engine. I'll be glad to share my experiences with individuals interested in a dialogue after my December delivery.
Tom Blejwas
12 Via Entrada
Sandia Park, NM 87047-9686
tomblejwas(at)yahoo.com (tomblejwas(at)yahoo.com)
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
mhubel
Posted: Fri Jul 08, 2011 3:03 pm Post subject: Viking Engine |
Tom,
If this is a 601XL you are planning to put it in, I was going back and forth with Viking on the engine mount and resulting W&B. It sounded to me like the default engine mount would position the engine too far aft and result in a CG that was a bit too far aft. Other than that, I am seriously considering swapping my Jabiru 3300 sometime in the next year.
On 07/08/2011 5:50 PM, Thomas Blejwas wrote: [quote] I have ordered a Viking Engine, which is a Honda Fit conversion. Anyone using this engine? I've watched the installation video and I'm impressed with the completeness of the conversion. Jan Eggenfellner has included some installation hardware, like a machined holder for the dual fuel pumps, which I find an improvement over what I've seen for UL installations. I'd really like to hear of any first-hand experience with the engine. I'll be glad to share my experiences with individuals interested in a dialogue after my December delivery.
Tom Blejwas
12 Via Entrada
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com (mhubel(at)nemon.com)
978-443-3955[b]
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
psm(at)att.net Guest
Posted: Fri Jul 08, 2011 4:22 pm Post subject: Viking Engine |
Hi Mark,
I was surprised to hear you want to trade your Jabiru aircraft engine
for an auto conversion. Have you been having problems with the Jabiru?
Paul
the next year.
mhubel
Posted: Fri Jul 08, 2011 6:07 pm Post subject: Viking Engine |
Paul,
I have a long list. There are many Jabiru engines that are happly
flying but there seems to be a certain element of hit and miss. The
engines are quite intollarent of being overheated. That is not good for
any engine but the Jabiru heads are especially sensitive. In the same
area, the Jabiru supplied oil cooler may not be sufficient. If your
engine is quite new, it may not be affected by the through bolt service
bulletin. Other things like noisy ignition and wimpy alternators, one
can work around. Some are happy with the Bing carbs. I found it to be
unacceptable but that can be replaced as well.
It is the head design and through bolt issue that is getting to me
to look at a design that a real professional team engineered. My thought
is that an engine that can take the beating of outboard motor service is
probably well designed. The fisherman I see go to near full throttle for
an hour or so to get to their spot. stop, (no letting it cool off) and
then do the same thing on the way back. I must say my use of an outboard
was probably worse, I used one for ski towing so it was effectively at
full throttle all the time. About the nastiest thing one can do to an
engine, yet they expect their engines to last a long time and apparently
they generally do.
That said, you should look to
http://groups.yahoo.com/group/jabiruengines/ and look at all the history
to get an ideal of how to best care for the Jabiru engine. It can be
used quite well if you are careful with it.
On 07/08/2011 8:19 PM, Paul Mulwitz wrote:
Quote: |
Hi Mark,
Paul
> Tom,
Mark Hubelbank
2 Clock Tower Place
Suite 555
mhubel(at)nemon.com
978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
Posted: Fri Jul 08, 2011 8:06 pm Post subject: Viking Engine |
Hi Mark,
Thanks for the information. I guess I have been living in a dream
world. Up until very recently I had heard about nothing but satisfied
owners of Jabiru engines.
I guess it makes sense that you shouldn't overheat an engine. The
outboard motors are probably water cooled, so overheating is not a real
issue. Air cooled engines are a different matter. The Jabiru 3300
generates a lot of power in a very small space. I guess it is not a big
surprise that heat and overheating are real issues.
Thanks for the link to the Yahoo group. I just signed up.
Good luck,
Paul
On 7/8/2011 7:04 PM, Mark Hubelbank wrote:
Quote: |
Paul,
for any engine but the Jabiru heads are especially sensitive. In the
same area, the Jabiru supplied oil cooler may not be sufficient. If
your engine is quite new, it may not be affected by the through bolt
service bulletin. Other things like noisy ignition and wimpy
alternators, one can work around. Some are happy with the Bing carbs.
I found it to be unacceptable but that can be replaced as well.
thought is that an engine that can take the beating of outboard motor
service is probably well designed. The fisherman I see go to near full
throttle for an hour or so to get to their spot. stop, (no letting it
cool off) and then do the same thing on the way back. I must say my
use of an outboard was probably worse, I used one for ski towing so it
was effectively at full throttle all the time. About the nastiest
thing one can do to an engine, yet they expect their engines to last a
long time and apparently they generally do.
history to get an ideal of how to best care for the Jabiru engine. It
can be used quite well if you are careful with it.
> Hi Mark,
> Paul
>> Tom,
