dan(at)azshowersolutions. Guest
Posted: Wed Jul 13, 2011 8:35 am Post subject: PTT issue |
As of this morning my PTT Buzz ghost is gone. I haven't done an engine start
yet, so I'm not going to do back-flips (don't wanna jinx it) but I am a happy
camper. As per my e-mail below to Bob N. , I started tracing wires and noticed
the red and white tristed pair which were "salvaged" wires meant for an engine
instrument. I know these thermocouple wires are dissimilar and now I know this
is a big no no to use them in a system for power or return.
Thanks Bob and All for the ideas and comments.
Dan B
----- Forwarded Message ----
| Quote: | From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
To: Dan Billingsley <dan(at)azshowersolutions.com>
Sent: Tue, July 12, 2011 9:59:17 PM
Subject: Re: PTT issue
At 02:56 PM 7/12/2011, you wrote:
> Bob, As I was working on the issue at hand with the PTT buzz, I noticed that
I
> used a twisted pair of theromocouple wire (originally intended for an engine
> instrument) as the hot wire from my buss to my on off toggle switch and then
> back to the hot wire on the radio. I remember taking a second look at using
this
> twisted pair while installing it, but dismissed it. I tend to think is is a
> non-issue as the radio works great while receiving, but I am now at the point
of
> troubleshooting I will entertain any plausible problem.
That needs to come out. TC wire is very high resistance stuff
and not at all suited to carrying power. In fact, a high resistance
in the power lead might very well be the cause of your problem.
Posted: Wed Jul 13, 2011 5:33 pm Post subject: PTT issue |
At 11:31 AM 7/13/2011, you wrote:
and noticed
an engine
know this
What Dan was experiencing was a manifestation of
'negative resistance' . . . a euphemism for the
effects on closed loop system stability where root cause
is an un-accounted for increase in resistance somewhere
in the loop. The resistance causes devices with gain to
believe they're seeing positive feedback. Positive feedback
+ gain can produce instabilities, i.e. oscillations.
The classic example discussed here on the list at
various times over the years was the "galloping ammeter"
in airplanes where the power path from the bus through
a breaker, alternator switch, ov protection system and
perhaps a dozen crimps and mated pins in connectors
was carrying BOTH field_current AND sense-voltage
for a simple regulator.
After years of service, the sum total of resistance
in this path might rise by several hundred milliohms.
At some point, this became a 'negative resistance' value
that caused the voltage regulator to 'chase' a moving
target for bus voltage . . . voltage the regulator could
SEE at the end of the wire was waving in the breeze in
response to changes of field current as the regulator
attempted to get it's arms around design goals.
Interestingly enough, many such problems appeared to
go away after a mechanic replace THE master switch or
THE circuit breaker. The mechanic would then pronounce
the replaced device as 'bad' and push the airplane
out the door . . . only to have it return in perhaps
a few months with the same problem.
This is discussed in more detail on page 9 of
http://www.aeroelectric.com/articles/Alternators/Know_Your_Charging_System.pdf
This is a situation where TOTAL replacement of all
components in the field-power/voltage-sense path would
offer a new lease on regulator stability probably for
tens of years.
Dan's situation involved a transceiver that didn't
draw enough current in receive to produce a distasteful
voltage at the back of the radio. But when he attempted
to transmit, the voltage fell below some value that
caused some part of the transmitter to shut down.
The current would drop, the transmitter would recover,
the offended circuit would do it's thing again. In this
case it was a pretty fast rate of shut-down, recovery and
shutdown that produced a near musical note.
These situations are pretty rare except where they are
literally designed in. The engineers that wired alternators
in Cessnas in 1968 had no idea that aging of the quality
of joints in that power/sense path over 30+ years would
cause the system to go unstable. None-the-less, it happens
on lots of older airplanes all the time and very few mechanics
understand why or how to really fix it.
Dan's particular discovery for this phenomenon turned
out to be a craftsmanship/materials issue. MUCH easier
to find and fix than design errors. His radio is going
to be just fine in 30 years . . . but as you read these
words, many an ammeter on lots of Piper and Cessna aircraft
is waving in the breeze.
Posted: Wed Jul 13, 2011 11:22 pm Post subject: PTT issue |
Thanks for the very well written explanation of negative resistance. I
appreciate all of the effort you give to this list...it is invaluable to so many
of us trying to learn/ understand the nature of these things called electrons.
The next time I rent an ole Cessna with a waving ammeter, I'll give it a wave
back for you.
Dan
