byoungplumbing(at)gmail.c Guest
Posted: Thu Jul 21, 2011 7:00 am Post subject: W&B |
i dont know why my last post last night did not come through, direct or in the digest mode.
by
According the the weight and balance sheet the a/c has a ew of 580.6 and a
moment of 17899.9. I weigh in around 225-230.
Travis
| Quote: | >>>>>>>>>>>>>>>>>>
first thing is not to assume anything,,,,, weigh the plane and make sure the
starting place is good..... or you will be adding insult to injury,,,
hopefully not your injury.
if the starting numbers include the plane and original owner,,,, that would
change every thing.
boyd young
tkben002
Joined: 06 Jul 2011 Posts: 54 Location: Alexandria, LA
Posted: Thu Jul 21, 2011 8:28 am Post subject: Re: W&B |
"if the starting numbers include the plane and original owner,,,, that would
change every thing. "
I am not sure I understand this. My assumption is that as long as the empty weight (and correct weight on each wheel) and the arm lenghts to the different stations are correct, then the individual weights are dynamic and would change in differing situations. (ie, different loading)
I know there are a few kolbra owners on here, hopefully they can share their own weight and balance.
Travis
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Thu Jul 21, 2011 12:24 pm Post subject: Re: W&B |
Travis,
Here is my Kolbra weight and balance numbers.
These are Mark German's numbers. I've flown the Kolbra with a 250lb passenger (80hp Rotax) and the climb was slow.
Mark put two trim systems on the Kolbra. One is a ground-adjustable trim on the elevator, and the fine adjust is a motor that tightens a bungee cord on the stick.
Mark also had to lower the leading edge of the stabilizer so it wouldn't dive.
Ralph B
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours
Richard Pike
Posted: Thu Jul 21, 2011 7:28 pm Post subject: Re: W&B |
Yet another unreadable post due to un-resized pictures.
Sigh...
Richard Pike
MKIII N420P (420ldPoops)
Posted: Thu Jul 21, 2011 8:01 pm Post subject: W&B |
Richard- I went to the lower right corner of my screen, where it says 100%. I clicked on it a couple of times, and it magnified the attachments to 150%. They were completely readable. Good luck.
Bill Sullivan
--- On Thu, 7/21/11, Richard Pike <richard(at)bcchapel.org> wrote:
Subject: Re: W&B
Date: Thursday, July 21, 2011, 11:28 PM
--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Sigh...
Richard Pike
http://forums.matronics.com/v h="http://forums.matronics.com/" target=_blank>http://forums.matronics.c &nbsf="http://www.matronics.com/contribution" =======
| [quote][b]
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Fri Jul 22, 2011 1:12 am Post subject: Re: W&B |
| Quote: | | Richard- I went to the lower right corner of my screen, . . . |
Alternatively, after clicking on the attachment and whilst viewing the picture, hold down the 'ctrl' button and press the '+' sign key until it comes up to a suitable size. (Hold down the 'ctrl' button & press the '-' key to get it back to original size)
David.
tkben002
Posted: Fri Jul 22, 2011 4:36 am Post subject: Re: W&B |
Thanks Ralph for posting your numbers. I was suprised our empty weights were so close. I expected the Jabiru to be lighter than the Rotax installation. (do you have a BRS). Our weights are pretty much the same except you have about 10 more pounds on the tail than I do. I am not sure I understand why yours has a different cg envelope (mine is 16 to 22.4)
Also, your youtube videos all say private now so I cannot see them. I watched them plenty of times while deciding if I was going to buy this Kolbra. Is your insurance going to replace your stolen engine?
thanks
Travis
Richard Pike
Posted: Fri Jul 22, 2011 5:17 am Post subject: Re: W&B |
When I said unreadable, it is because the
images are so large that in order to read
any of the posts, you have to get the
scroll bar at the bottom of the screen
and toggle the whole mess back and forth
for each printed line. (Unless you hit the
enter bar after every 6 or 7 words when
composing your post like I am doing here.)
It was not that the images were too small,
quite the opposite. The reason I said they
were unreadable is because I lose interest
and leave them unread. But maybe that's
just me. Shalom.
Richard Pike
by0ung(at)q.com Guest
Posted: Fri Jul 22, 2011 6:35 am Post subject: W&B |
David.
that is a new shortcut that i really like... thanks i had been
using the zoom function in the bottom right. but the ctrl +/- is way nice
boyd young
rlaird
Posted: Fri Jul 22, 2011 7:01 am Post subject: W&B |
If your mouse has a wheel on it, you can also press and hold down the CTRL key and then use the mouse wheel to increase/decrease font size.... well, for Kolb related stuff, anyway.
On Fri, Jul 22, 2011 at 9:33 AM, b young <by0ung(at)q.com (by0ung(at)q.com)> wrote:
[quote]--> Kolb-List message posted by: "b young" <by0ung(at)q.com (by0ung(at)q.com)>
David.
that is a new shortcut that i really like... thanks i had been using the zoom function in the bottom right. but the ctrl +/- is way nice
boyd young
le, List Admin.
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Richard Pike
Posted: Fri Jul 22, 2011 4:16 pm Post subject: Re: W&B |
| by0ung(at)q.com wrote: | hold down the 'ctrl' button and press the '+' sign key until it comes up to a suitable size. (Hold down the 'ctrl' button & press the '-' key to get it back to original size)
Thank You! This makes things tolerable! You da man!
Richard Pike
Ralph B
Posted: Mon Jul 25, 2011 6:09 am Post subject: Re: W&B |
tkben002 | Quote: | Thanks Ralph for posting your numbers. I was suprised our empty weights were so close. I expected the Jabiru to be lighter than the Rotax installation. (do you have a BRS). Our weights are pretty much the same except you have about 10 more pounds on the tail than I do. I am not sure I understand why yours has a different cg envelope (mine is 16 to 22.4)
thanks
Travis |
Travis and others,
I'm still mourning the loss of my Kolbra as I didn't have theft insurance on it. I'm in retirement and living on a fixed income. I don't have a whole lot of money to spend on an engine and avionics. I am thinking of going back to work to save for this, but it will take some time. When it's done, the Kolbra would be better than it was before with new equipment.
Who would have thought someone would break into a locked hanger and steal the engine and panel in the middle of the night? I hope these guys know they are looking at a minimum of 5 years in a federal prison for doing this.
I didn't have a BRS on the airplane. In fact, I've never flown with a BRS on the Firestar either.
I was just starting to make videos when the break-in occurred. I was enjoying making them with my openness and showing all my friends the fun and thrill of flying including those guys that wanted my engine. It showed them where I was located and which hanger I was in. Please let this be a lesson for anyone making public videos on the internet.
I hope my engine and panel don't show up for sale at AirVenture. Please keep an eye out for it. In the 8 years we've attended the convention,
this is the first year Laurie and I haven't been there.
Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
