Liquid Cooled Heads...
don.honabach(at)pcperfect
PostPosted: Thu Jul 21, 2011 7:53 am    Post subject: Liquid Cooled Heads... Reply with quote
Saw an ad for this product today in KitPlanes – liquid cooled heads for the Jabiru Engines.
http://www.rotecaerosport.com/product-info/lch/
I rarely have cooling problems on my 3300A. Evening though I’m in Arizona, worst case is if the engine gets heat soaked on the ground I have to baby the plane to altitude to avoid going over 350F CHTs during our hot summer days.
That said, I know others do and this seems like an interesting product. If nothing else, I would feel better about ‘de-stressing the engine’ by running it cooler and distributing the heat load evenly which is impossible to do with the air cooled/carb setup.
Pete, any thoughts on this?
Thanks!
Don Honabach
Tempe, AZ
Zodiac 601HDS – 3300A (~200 Hours)
aerobiz1(at)gmail.com
PostPosted: Thu Jul 21, 2011 3:15 pm    Post subject: Liquid Cooled Heads... Reply with quote
Hi Don,
I have just completed fitting a set of the Rotec Liquid Cooled Heads on a J230 that had chronic overheating issues, such that it had to have two heads reconditioned at less than 100 hrs from new, and again at 200 hrs.  I made some mods to the carb and induction plenum to try and get better distribution, but the LC heads have made a huge difference.
I have even gone down 2 sizes in main jet  (#245)  and temps are , if anything, a bit on the cool side.  Very straightforward to fit and sort out the plumbing.  Added 16 lbs to the weight, but am looking at ditching the muffler and running a pair of 3-1 collectors, which should get about 5-6 lbs off.
We have tried everything else, and it has worked for us.
Martin
On Fri, Jul 22, 2011 at 1:52 AM, Don Honabach <don.honabach(at)pcperfect.com (don.honabach(at)pcperfect.com)> wrote:
Thanks!
Don Honabach
Tempe, AZ
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
djtoddb
PostPosted: Thu Jul 21, 2011 8:28 pm    Post subject: Liquid Cooled Heads... Reply with quote
I am also in Phoenix and have a Hyd 3300 on a Titan Tornado and am concerned about High Temps and Head Wear. The water cooled heads look good but are a bit pricey. I am also concerned that the 20 amp Alternator will not put out enough current to run the water pump as I already have low amperage issues. Does anyone know what our original heads are worth in attempt to sell them to offset the cost of the water cooled heads?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Todd Bristol
Great Entertainment isn't expensive... It's Priceless!
Interactive Entertainment Events, DJs and Game Shows
Mesa, Arizona
480-755-4200
www.djs4u.com
www.gameshowsamerica.com
www.condopenasco.com
--- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com> wrote:
Subject: Re: Liquid Cooled Heads...
To: jabiruengine-list(at)matronics.com
Date: Thursday, July 21, 2011, 4:11 PM
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-List
et=_blank>http://forums.matronics.com
Titan Tornado II with Jab 3300
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu Jul 21, 2011 10:36 pm    Post subject: Liquid Cooled Heads... Reply with quote
Hi Todd.
I don't think the old heads will be worth much.  I do know that the Rotec LC heads are CHEAPER than the Jabiru ones.  You have a valid point about alternator output.  We used the larger of the two electric water pumps available, and it has not been an issue with the J230 which has a full glass panel , strobes, beacon, GPS etc..  We do have the pump wired to a separate switch for starting, but after jetting the carb it is starting easily in the cold weather we have this time of year.
Cheers
Martin
On Fri, Jul 22, 2011 at 2:24 PM, Todd Bristol <djtoddb(at)yahoo.com (djtoddb(at)yahoo.com)> wrote:
Todd Bristol
Mesa, Arizona
[url=tel:480-755-4200]480-755-4200[/url]
www.djs4u.com
--- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)> wrote:
From: Martin Hone <aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)>
Subject: Re: JabiruEngine-List: Liquid Cooled Heads...
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Hi Don,
Martin
On Fri, Jul 22, 2011 at 1:52 AM, Don Honabach <don.honabach(at)pcperfect.com> wrote:
Thanks!
Don Honabach
Tempe, AZ
mhubel
PostPosted: Fri Jul 22, 2011 4:43 am    Post subject: Liquid Cooled Heads... Reply with quote
Todd,
    For the record, I replaced all the strobes and position lights with LED types and reduced the current demand significantly, Now all the lights together are an average of about 1 amp. The Jabiru does not have much margin but with the LED lights, I believe the load of the water pump could be tolerated.
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com
--- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com> (aerobiz1(at)gmail.com) wrote:
From: Martin Hone <aerobiz1(at)gmail.com> (aerobiz1(at)gmail.com)
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com (mhubel(at)nemon.com)
978-443-3955
Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com
PostPosted: Fri Jul 22, 2011 10:24 am    Post subject: Liquid Cooled Heads... Reply with quote
For what it worth, I have the LED setup on my plane and love it and was pretty much essential after seeing the AMP draw of traditional landing light(s), strobes, etc.
Just thinking out loud …
One of the things I’ve been tossing around in the back of my head is to switch out the bing carb. I tend to like to fly at the higher power ratings and get taxed heavily with excessive fuel burn rates using the bing carb. As such, going to a more traditional carb where I can adjust the mixture might make sense and would solve the high burn rate issue (assumption here?),  as would probably messing with the bing needles if I stuck with a bing carb. In either case though, if I do that, chances are my temps will climb so it is a bit of a balancing act for sure. I’m thinking that the LC heads would allow me to have the best of both worlds (low fuel burn rates, high power settings, low temps) even on a hot day sort of thing…
Don
P.S. Todd, where are you based in AZ? Any chance over at P19? I thought I saw a Titan there the other day. If so, I’m the red/white Zodie by the fuel pumps.
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Mark Hubelbank
Sent: Friday, July 22, 2011 5:41 AM
Todd,
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
  ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
  ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-Listet=_blank>http://forums.matronics.com
PostPosted: Fri Jul 22, 2011 10:29 am    Post subject: Liquid Cooled Heads... Reply with quote
Martin -
Any chance you could post some pics of the install? In particular anything that would show the water radiator and installation?
Thanks!
Don
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Todd Bristol
Sent: Thursday, July 21, 2011 9:25 PM
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com<http://www.djs4u.com/>
www.gameshowsamerica.com<http://www.gameshowsamerica.com>
www.condopenasco.com<http://www.condopenasco.com>
--- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com<mailto:aerobiz1(at)gmail.com>> wrote:
From: Martin Hone <aerobiz1(at)gmail.com<mailto:aerobiz1(at)gmail.com>>
To: jabiruengine-list(at)matronics.com<mailto:jabiruengine-list(at)matronics.com>
Hi Don,
Martin
On Fri, Jul 22, 2011 at 1:52 AM, Don Honabach <don.honabach(at)pcperfect.com<http://us.mc1608.mail.yahoo.com/mc/compose?to=don.honabach(at)pcperfect.com>> wrote:
Thanks!
Don Honabach
Tempe, AZ
Charles R Gallagher
PostPosted: Fri Jul 22, 2011 10:50 am    Post subject: Liquid Cooled Heads... Reply with quote
Don,check YOUTUBE...search .Rotec see it there in action. CRG
To: "jabiruengine-list(at)matronics.com" <jabiruengine-list(at)matronics.com>
Sent: Friday, July 22, 2011 1:28 PM
Subject: RE: Liquid Cooled Heads...
Martin -
Any chance you could post some pics of the install? In particular anything that would show the water radiator and installation?Â
Thanks!
Don
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
¦·›~‰í²,Þg(–ŠÓM4ÓGÚqü¢êâz¹ÞÁÊ.®'«8^%¦â®á'‚)Þ.+-f¢”Z+ºt±ëaxÆ­®‰ârÂâ²Ñ^jÛ«zÃZ¾(¶Ší¡ºèÂǶ¦j|‹ŠËn¶)b¶'¬²ç!jÂâ²Õ'ý+›±Êâ¦Ø¨œ+r¯y'š­ÈC£ å¡§{ ¬�®Œ,x(Z´P
PostPosted: Fri Jul 22, 2011 11:02 am    Post subject: Liquid Cooled Heads... Reply with quote
Thanks!
Don
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Charles Gallagher
Sent: Friday, July 22, 2011 11:48 AM
Subject: RE: JabiruEngine-List: Liquid Cooled Heads...
Martin -
Thanks!
Don
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
5
6
7
8
9
5
6
7
8
9
PostPosted: Fri Jul 22, 2011 1:33 pm    Post subject: Liquid Cooled Heads... Reply with quote
Hi Don,
As Richard pointed out, there is a lot on Youtube, but the Rotec website is full of great stuff.  If you want pics of our own installation, email me directly and I can send to you.  Our installation is overly conservative.  We live in a hot part of the world so I oversized the radiator and placed it directly under the prop.  I had to add an inline thermostat to get some temps into it. When I do another one, the radiator will be 1/2 the size and placed under the engine.
Cheers
Martin
On Sat, Jul 23, 2011 at 4:28 AM, Don Honabach <don.honabach(at)pcperfect.com (don.honabach(at)pcperfect.com)> wrote:
Martin -
Thanks!
Don
From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Todd Bristol
Todd Bristol
Mesa, Arizona
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
2 7-Day Browse, Chat, FAQ,[/b]
http://www.matronics.com/Navigator?JabiruEngine-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List[/b][/quote]           - MATRONICS WEB FORUMS a the Web Forums![/b][/quote] ef="http://forums.matronics.com" target="_blank">http://forums.matronic============[/b][/quote]    - List Contribution Web Site -[/b] [/quote]3 bution" target="_blank">http://www.matronics.com/contribution<===================[/b] [/quote]4
PostPosted: Fri Jul 22, 2011 1:40 pm    Post subject: Liquid Cooled Heads... Reply with quote
Don,
You have a few options regarding a mixture adjusting carb - Aerocarb, Ellison TB and Rotec TB.  I have used both the Aerocarb and the Rotec TBI, and the Rotec unit is the more sophisticated.  If you are running unleaded fuel, you might also like to consider adding a wide-band Air Fuel Ratio meter. Makes getting the correct mixture a breeze.
Also permits running LOP if you are interested in another tin of worms......
Cheers
Martin
On Sat, Jul 23, 2011 at 4:23 AM, Don Honabach <don.honabach(at)pcperfect.com (don.honabach(at)pcperfect.com)> wrote:
Don
From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Mark Hubelbank
Todd,
Todd Bristol
Mesa, Arizona
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
Lynn Matteson
PostPosted: Fri Jul 22, 2011 4:10 pm    Post subject: Liquid Cooled Heads... Reply with quote
What make of A/F meter do you have, Martin? Answer quickly, as I'm
heading to Oshkosh with room on my credit card (but none on my
panel....drats!). : )
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with "Ramcharger" intake manifold...1142 hrs (since
3-27-2006)
On Jul 22, 2011, at 5:37 PM, Martin Hone wrote:
Don,
mixture a breeze.
worms.......
Cheers
Martin
thing…
Don
Todd,
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
JabiruEngine-List tp://forums.matronics.com_blank">http://
Navigator?JabiruEngine-List et=_blank>http://
forums.matronics.comllow target=_blank>http://www.matronics.com/
contribution
-- Mark Hubelbank NorthEast Monitoring2 Clock Tower PlaceSuite
555Maynard, MA, 01754 - USAmhubel(at)nemon.com 978-443-3955
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Fri Jul 22, 2011 5:43 pm    Post subject: Liquid Cooled Heads... Reply with quote
I bought a FAST gauge (analogue, but they have digital)  from JEGS in the States. Love it.
Not sure they will be at OSH though
Marty
On Sat, Jul 23, 2011 at 10:07 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
What make of A/F meter do you have, Martin? Answer quickly, as I'm heading to Oshkosh with room on my credit card (but none on my panel....drats!).    : )
Lynn Matteson
Jabiru 2200, #2062
Status: flying with "Ramcharger" intake manifold...1142 hrs (since 3-27-2006)
Don,
Cheers
Martin
Don
Todd,
Todd Bristol
Mesa, Arizona
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
 ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List tp://forums.matronics.com_blank">http://www.matronics.com/contribution
 ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-List et=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution
-- Mark Hubelbank NorthEast Monitoring2 Clock Tower PlaceSuite 555Maynard, MA, 01754 - USAmhubel(at)nemon.com (USAmhubel(at)nemon.com) [url=tel:978-443-3955]978-443-3955[/url]
www.mat=============================================
MS -
e -
         -Matt Dralle, List Admin.
Lynn Matteson
PostPosted: Fri Jul 22, 2011 5:55 pm    Post subject: Liquid Cooled Heads... Reply with quote
Thanks, Marty....I'll look at Osh, but for the Jegs stuff I'll wait
until I get back home and then check 'em out.
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
Marty
On Sat, Jul 23, 2011 at 10:07 AM, Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
Don,
mixture a breeze.
worms.......
Cheers
Martin
thing…
Don
Todd,
Todd Bristol
Mesa, Arizona
480-755-4200
www.djs4u.com
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
JabiruEngine-List
MS -
e -
Lynn
N369LM
PostPosted: Tue Jul 26, 2011 1:37 pm    Post subject: Liquid Cooled Heads... Reply with quote
Martin,
Thanks for all the great advice! Didn’t even know about the Air Fuel Ratio Meters – did a quick search – those are cool and I do love my gadgets <g>!
Thanks!
Don
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Martin Hone
Sent: Friday, July 22, 2011 2:38 PM
Don,
Also permits running LOP if you are interested in another tin of worms.......
Cheers
Martin
On Sat, Jul 23, 2011 at 4:23 AM, Don Honabach <don.honabach(at)pcperfect.com<mailto:don.honabach(at)pcperfect.com>> wrote:
Don
From: owner-jabiruengine-list-server(at)matronics.com<mailto:owner-jabiruengine-list-server(at)matronics.com> [mailto:owner-jabiruengine-list-server(at)matronics.com<mailto:owner-jabiruengine-list-server(at)matronics.com>] On Behalf Of Mark Hubelbank
Todd,
Todd Bristol
Mesa, Arizona
480-755-4200<tel:480-755-4200>
--- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com><mailto:aerobiz1(at)gmail.com> wrote:
From: Martin Hone <aerobiz1(at)gmail.com><mailto:aerobiz1(at)gmail.com>
Hi Don,
Martin
Thanks!
Don Honabach
Tempe, AZ
tp://forums.matronics.com<http://forums.matronics.com>
Mark Hubelbank
2 Clock Tower Place
Suite 555
mhubel(at)nemon.com<mailto:mhubel(at)nemon.com>
978-443-3955<tel:978-443-3955>
PostPosted: Tue Jul 26, 2011 1:56 pm    Post subject: Liquid Cooled Heads... Reply with quote
Don,
I am really impressed with the AFR gauge. Whilst it doesn't monitor each
individual cylinder, it does tell you what the engine is doing mixture-wise
